Suggestions for mounting a 5Lb propane tank?
Re: Suggestions for mounting a 5Lb propane tank?
Postby S. Heisley » Sat Feb 26, 2022 7:04 pm
That looks really good! :thumbsup:
Postby wysedav » Sun Feb 27, 2022 8:25 am
This is mine, I had the unbolt laying around. I used an opt lawnmower tire rim cut in had for the base and som scrap 2x2 fro the structure. Got about 20k miles on it now, with no issues.
wysedav
Postby wysedav » Sun Feb 27, 2022 8:42 am
Sorry not sure why the picture was cut off. It didn’t take long, was exactly what I needed, was basically free, and building a teardrop isn’t a race.
wysedav
Postby tony.latham » Sun Feb 27, 2022 10:35 am
What do you guys think?
I like it. Did you add some padding or something between the bracket and the tank?
Postby TearDropDrippin » Sun Feb 27, 2022 12:08 pm
Yes I plan on like a heavy duty bike tire to help the vibration from marring the tank. As well as some blocks or something to help brace the bottom of the tank and a steel wire/chain as a fail safe back up.
TearDropDrippin
Postby Woodenmusic » Sat Mar 18, 2023 10:58 am
This discussion leads to my question.... would it be safe to secure a 5 pound tank inside the tongue box, and then take it to the back of the trailer when it's time to cook? Or must it be secured outside?
Woodenmusic
Postby Sparksalot » Sat Mar 18, 2023 1:31 pm
I used the bracket for a 20# fire extinguisher for my 5# flame king tank. About $50.
Sparksalot
Images: 687
Postby tony.latham » Sat Mar 18, 2023 9:41 pm
would it be safe ...
I wouldn't have a problem with it.
Postby Onajourney » Tue Mar 21, 2023 10:49 am
Sparksalot wrote:I used the bracket for a 20# fire extinguisher for my 5# flame king tank. About $50.
I see that the 20# fire extinguisher brackets are for 7" but the 5# propane bottles are 8". It still works?
Onajourney
Images: 181
Postby Sparksalot » Tue Mar 21, 2023 11:59 am
If I recall mine was from Kidde, and my tank is Flame King. It’s was very close. I only had to adjust the strap a bit to get it to work fine.
171575
Sparksalot
Images: 687
