grey/black water tanks - how to attach
Postby aggie79 » Fri May 27, 2011 8:36 am
Please excuse another rookie question. How do you attach the grey/black water tanks to the frame/deck?
I've seen tanks that have flanges and some that don't. For the flanged tanks, I assume you screw/bolt them to the bottom of the trailer frame/deck. For the non-flanged models, I assume you use strapping or bolts and Uni-strut.
Thank you for your replies.
Postby 48Rob » Fri May 27, 2011 5:59 pm
Tom,
Most use angle iron.
Some alone, just along the edges of the tank, and some with plywood spanning the angle iron to help support a wide tank.
Rob
48Rob
Postby kirkman » Fri May 27, 2011 8:56 pm
I used pluming strap. The kind you use to support sewer pipe. It comes in 10, 20, 50 foot rolls I think.
kirkman
Images: 55
Users browsing this forum: Google [Bot] and 1 guest
