Ron,
Sorry, I lost track of this post...
Here are a couple pictures of the pump setup.
This is "in the toolbox"
<img src="http://im1.shutterfly.com/media/47a1cc31b3127ccefe80fe2cfc0500000030O02AbNGjdu5bMge3nww/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/">
And this is the pump out of the box.
It is all mounted on a piece of plywood so it can be easily removed for cleaning the toolbox.
<IMG SRC="http://im1.shutterfly.com/media/47a1cc31b3127ccefe81df471d9a00000030O02AbNGjdu5bMge3nww/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/">
The green hose is connected to the water line, and the white suction hose is placed in the bottle of anti freeze.
When the pump is turned on, it draws antifreeze though the white hose into the pump, then pushes it through the green hose and the plumbing lines to the faucets/appliances, where the fresh water is forced out by the anti freeze.
To use such a setup for a shower, the white hose goes in a bucket of water, and a shower head is attached to the end of the green hose.
It should be noted that one of my guys who was having a senior moment cut the wires and removed the quick connect couplers so he could "test" them after trying to turn on the pump and getting nothing.
(I don't build things with bare wires hanging out...
The quick connect couplers allowed the battery to be disconnected from the pump, and the battery charger connected.
The original 12 Amp hour battery I installed has been changed to a smaller 4 Amp hour battery because the original went bad and they were in a hurry.
He turned on the switch on the end of the pump, and couldn't figure out why it wouldn't turn on.
He "forgot" that the pump, while equipped with an on/off switch, is also a "pressure switch".
When the switch is turned on, it pumps liquid until a preset pressure is reached (usually 35-50 pounds) then the pump shuts off by itself.
It comes on again when it senses a loss of pressure, such as turning on a faucet.
Since we have a shutoff on the end of the green hose, whoever used it last left the valve closed while the pump was on.
Since there was "pressure" in the line, the pump didn't turn on.
As soon as I opened the valve and relieved the pressure, the pump kicked on.
Rob
