Propane gas line
Now that I have the Bullfinch gas point I am bumping up against the gas line. One of the problems with Compass Rose is the gas line from the front of the trailer. They followed the RVIA standard and used black steel line under the trailer. Unfortunately it was a half assed job, There is a drop that sticks three or four inches below the axle, it is the lowest point of the trailer and just waiting for a rock to come along and do a lot of damage. On top of this it provides a place for water to accumulate. It gets worse, from there as they used copper line up through the floor and the hole is not sealed and the copper is kinked/crimped where they tried to bend it with out using a spring or tubing bender.
RVIA standards or not the black steel is as far as I am concerned a goner, and that leaves two choices polyethylene (the yellow pipe used by utilities) or copper. Polyethylene seems to be A, difficult to install and B, only UV stabilized for three to five years so I guess this means copper.
I am suspecting that RVIA standards call for black steel because of home standards. Sulfur in natural gas will cause the inside of conventional copper to flake.
I have not worked with copper before other than to test for leaks so I am looking for insight
