RV tank and Toilet
Posted:
Sat May 09, 2015 7:35 pm
by RetchedOne
I'm doing a Cargo Conversion, and have 2 40 gallon tanks below, one grey, one black. The black will be directly below the toilet, with just a 3/4 ply floor separating the tank top and toilet floor. I'm using a standard RV toilet.
How does the toilet attach to a black tank? I see fittings that look like I cut a 3.5 inch hole, and they pop in place and get sealed... then what???? Can anyone provide links to what I need?
Thanks all!
Re: RV tank and Toilet
Posted:
Sat May 09, 2015 8:13 pm
by MtnDon
That's about it. Hook up a fresh water line to flush, add a vent pipe and there ya go.
I guess I don't understand the question.
Posted:
Sat May 09, 2015 8:14 pm
by RetchedOne
What fittings go between the bottom of the toilet to the tank?
Posted:
Sat May 09, 2015 9:42 pm
by RetchedOne
Posted:
Tue May 17, 2016 5:12 am
by Iconfabul8
I believe your questions is, " how do you attach/glue/mount the toilet flange to the tank?" I too have been a little curious about this.
Maybe this:
http://www.campingworld.com/shopping/it ... slip/68818And this:
http://www.campingworld.com/shopping/it ... ange/68820
Posted:
Mon May 23, 2016 8:11 pm
by msnglinc
I too am interested in this. About to start the bathroom of my cargo conversion and need to gather parts.
Posted:
Mon May 23, 2016 8:37 pm
by Redneck Teepee
You will have to get from your tank connection on top to what is called a Herco Ring or closet flange. The blue ring at left in the picture is the herco ring, it's what you bolt your toilet to, it rotates so you can clock it any direction to orientate your toilet square with the room or whatever.
http://www.gumpydog.com/Bus/MC9_WIP/Plu ... bfloor.JPG
Posted:
Tue May 24, 2016 2:00 pm
by Tommy B
Retched, I am in a similar situation. If you check out my thread there are pictures of what you are describing. I used a 3 inch valtera floor flange which required a 4 in hole I BELEIVE. Much has passed sense I cut that hole But I could confirm if need be. My tank will be here this Friday and I plan on mounting it sat if all goes well. The flange fits tight and flush and passes through that 3/4 inch plywood with much thread to spare to screw into your tank fitting. It is a male 3 inch valtera floor flange. I have no idea how I will mount the tank and there is no easy button.
Cargo conversion thread. 6x12 hallmark thread will have better pic. I don't have time right now good luck.
