Holding tank revision - need fittings suggestions.
Hey all. It's a long story but I'm redoing a mixed black/grey (solo) holding tank on our latest mini-trailer and making it strictly grey and then adding a cartridge toilet instead which is a far more convenient setup. The existing tank was leaky, the single mixed tank wasn't ideal, and when I dropped it, it didn't take me long to figure out why it was leaky - the installation (either factory, or some previous owners modification) was a total gong show with caulking trying to make up for it. I think Ray Charles cut the hole, suffice to say.
Anyhow, I have the tank at a reputable plastic welding shop getting returned to basically new (and hole-less) condition. It's in otherwise good condition and was a waste to throw away when I could get it fully repaired for 1/3 the cost of a new replacement.
For the revised setup I need 3 (probably 1" will be fine) holes on the top of the tank near where the toilet used to drain into. 1 for the galley sink, 1 for the shower, and 1 for the vent.
I'm struggling to figure out what fittings may work best for mating onto a flush ABS surface. Ideally I want them as flush as possible, and inside threaded - that way I can adapt whatever fittings I need externally beyond that point without having to disturb the tank side. Something that can either be threaded in from behind (Although that could be difficult, but not insurmountable) or fused using ABS glue would be preferable - it MUST be waterproof when it's all said and done as the tank is flush fitting against the floor of the trailer underneath - any water leakage will contribute to rot as it gets trapped between the tank and the floor. The fresh tank is also bigger than the sum of the toilet and grey so when it's full....I want it to come out the overboard dump/vent, not seep anywhere else and rot out my floor.
Anyone have any suggestions?
