First and foremost to me is how structural is the roof? Will it require 'stays' or just foam? I assume 1 1/2" thick.. I'm about 11'-9" long x 7'-5" wide.
[img]
pchast wrote:Welcome.....![]()
a bunch of choices.... sheet metal forms, channel or I beam. wood in the seams. Use of both depends on the span, thickness and spacing of your roof panels. You will find several different types of adhesives used. The rounded, or teardrop, roof is improved, stiffened, by its curved form also. The skin is a large part of the foamy's strength.
Your best bet is to take some time to read and investigate what has been done.
Most of our construction approaches have been arrived at by home testing.
There are no Engineering tables nor data I'm aware of.......
GPW wrote:RJ , your design looks really good , the angular semi rounded shape should be very strong … And if you don’t plan on standing on the roof you should be fine … Once you put a skin on foam , it’s no longer just foam , but composite construction … Much stronger than you’d imagine of just foam … And the old adage here is “when in doubt , make the foam THICKER …. Mine is 3.5” thick … Plus you’re welcome to add any bracing you can think of …but that just adds weight, so be careful there…
Just keep asking questions , somebody here will have the answer you need …
