One more line
Re: One more line
Postby twisted lines » Thu May 16, 2024 7:33 pm
Last one, because it told me only 3 pictures!
Have the wheelbase set now :worship: near finished with the frame.
Now it's built to fit instead of as drawn.
Racking up; And Rapin foam
twisted lines
Re: One more line
Postby twisted lines » Sun May 26, 2024 7:05 pm
After cutting 2" off the back and tapering it to the front,
This is where the difference shows up! (The piece that's too tall with a pencil line)
Little worried about a drip edge.
Sides will be the same angle in, as the top that's marked comes down. :worship:
twisted lines
Re: One more line
Postby twisted lines » Sun Jun 02, 2024 9:22 am
Trimmed both rear sides, Think Ill like it.
And started the back of the Frame / Bumper;
Need's leveled, either the tape will hold it or not :lol:
dirt side.jpg (28.19 KiB) Viewed 332 times
twisted lines
Re: One more line
Postby twisted lines » Wed Jun 05, 2024 10:30 am
Spent two days cutting, tweeking 1 tube a little bit in two directions,
because eyeballed wasn't close enough!
And it's for Alignment.
Second picture shows the rear bumper tacked on.
twisted lines
Re: One more line
Postby twisted lines » Thu Jun 06, 2024 3:41 pm
A few day's ago I stopped and :thinking: Naaaa...
wrong side up.jpg (43.05 KiB) Viewed 262 times
twisted lines
Re: One more line
Postby twisted lines » Fri Jun 07, 2024 1:57 pm
Just checking and without a tire it looks like the opening is too big,
so, I put one on.
Now to Back to removable mounts :shock:
No tire..jpg (40.61 KiB) Viewed 233 times
twisted lines
Re: One more line
Postby twisted lines » Fri Jun 14, 2024 4:11 pm
Rounding the corner's I can;
And trying to figure out the rest ;)
Round over.jpg (31.99 KiB) Viewed 167 times
twisted lines
Re: One more line
Postby twisted lines » Sun Jun 16, 2024 3:18 pm
Last night I attached the rear two pieces using a jig to set the angle, hope there still hanging!
Now I have a stumper ?
Sag in the roof 1/4" to 1/2".
Using 2" foam not attached span 75" X 8'
Pieces are cut just resting in place :lol:
Hang it upside down then FG :thinking:
FG with a tiny crown then attach ?
As my wife still wonders if the floor will hold her weight let alone mine :lol:
twisted lines
