Those who have done the actual PMF process could maybe shed some light on the possibilities.
I'm curious if anyone has tried to eliminate the canvas overlap by pressing the edges of the canvas from two sections of canvas, into a narrow groove, then when dry, caulked the groove with a nice bead of urethane? Just looking for a way to make things more FLUSH.
For example, on a project with a 2" foam roof hung over the top edge of a 1/2" foam sidewall, lets say you cut a nice clean groove into the foam on the roof, 1" deep, 1-1/2" in from the sidewall. The side wall canvas goes up and over and gets tucked in. Then the center roof section of canvas gets tucked in. When Dry, it gets caulked (urethane).
I can't see any "leaking" issues with this concept, and I think the strength is pretty much still there with the canvas glued to each other and the caulk. The end finish would probably be Bed Liner.
I have not played with PMF, but I'm assume that canvas fibre does not "flare" itself for smooth curves like glass cloth does. So I don't know how far it would go over any radiused edges before bunching.
Yep, I know... I need to test this myself, but just kicking some ideas around before I commit to a design that uses PMF.
