paint and cloth?
paint and cloth?
Postby 48Rob » Thu Jul 12, 2012 10:27 am
Can I use oil based paint with bed sheets or must it be glue, latex, etc?
Can I rough up oil based paint surface and apply "patches" of paint and coth over existing surface?
Anyone try elastomeric roof coating (snow roof?).
Rob
48Rob
Re: paint and cloth?
Postby eaglesdare » Thu Jul 12, 2012 11:22 am
these are technical questions, so i will leave this alone. waiting on others to answer. i am sure gpw as well as others will chime in here.
gpw???
Louella
May the foam be with you.
eaglesdare
Postby starleen2 » Thu Jul 12, 2012 2:43 pm
Maybe this will helps some
viewtopic.php?t=42125&p=784040
starleen2
5th Teardrop Club
Postby angib » Thu Jul 12, 2012 2:58 pm
Rob, the traditional way of covering boat cabin roofs was oil-based paint over heavy canvas. And I think the initial coats of paint were a mix of whatever was lying around in the bottom of unfinished tins under the workshop bench (none of that flammable stores stuff back then....).
angib
5000 Club
5000 Club
Images: 231
Postby GPW » Thu Jul 12, 2012 4:56 pm
That should work huh ??? The recommended procedure around here is to try it on a piece of scrap first ... :thumbsup:
Postby 48Rob » Thu Jul 12, 2012 5:44 pm
Thanks all, for the advice and links! :thumbsup:
Rob
48Rob
Postby mezmo » Fri Jul 13, 2012 1:45 am
Hi Rob,
Here are some links I've run across on this topic.
An Aussie Restoration using paint and 'calico':
"Fisher's Resto":
http://vintagecaravans.proboards.com/in ... 935&page=1
http://vintagecaravans.proboards.com/in ... 935&page=2
Here's a link to fellow forum member rowerwet's post in "TD Construction
Tips & Techniques". It's an account of his experience using paint & canvas
as an exterior finish for his TD.
http://tnttt.com/viewtopic.php?t=45468
Desertmoose's 'HornyToad' build also has it:
http://tnttt.com/viewtopic.php?t=45718
And rayvillian used paint and bedsheets on his latest Winter Warrior.
Just look him up under the "Members" feature and I'm sure you can find
his info on that.
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby 48Rob » Fri Jul 13, 2012 6:12 am
Thank you Norm.
Rob
48Rob
