GPW wrote:KC, you didn’t inset your hinges???
Nope.
BTW, is that sarcasm?
My door gap is 1/4 inch plus a sliver here and there. The leaves of the hinges are barely 1/8 inch thk and fold back on themselves one over top of the other, single thickness (MC PN 12575A72), so I have to make up about 1/8+ inch. This way when I wrap the canvas around the door opening and frame I won't have to worry about following little itty bitty contours. After canvas, dry fit the hinges; fill screw holes with TB2 or CA then chase with the screws; allow to dry; paint & final finish; if the door gaps are still greater than 1/8 inch, make shims; install hinges (shim as req'd) over the painted canvas in a bed of some sort of gooey stuff (probably 3M 4200). That's my plan, anyway.
This leads to the question, again: does anyone have a real, actual, true, real life scientifically observed thickness of actual canvas and glue/paint? (I realize that there are different weights of canvas and some will want to fill the grain, etc., but I'm going on the assumption that it will be around 1/16 inch thk... so hinge shims may not even be needed if my door gap shrinks to 1/8 inch after canvas.
I may even have to shave some wood first if I end up doubling up on the canvas around edges.
Maybe the first reinforcing layer will be flannel bed sheet instead of canvas.
Guess I’ll have to do a test of my technique before committing to the covering. Sure would suck hard to have the door and wall all covered up and have to mortise the hinges in afterwards… or worse, have the door not fit in the opening!
At 1/4 inch I don't need any additional lead (chamfer) in the doors, but as that gap gets smaller I may have to lay an edge back (bevel the latch edge) to allow for the swing… the arc of the trailing edge of the latch side of the door.
You know, the thicker the door, the narrower the door opening between jambs, the narrower the door gap, and the more the hinge pin centerline sits out from the face of the door, the more likely that the trailing edge of the door will bind on the door opening when it swings.
My doors are fairly wide, so that mitigates the opening width vs. door thickness ratio.
Hmm
...mind that gap!
