Fiberglass is really expensive and I feel like I am going to need a TON of it!
tony.latham wrote:EZ is spot on.Fiberglass is really expensive and I feel like I am going to need a TON of it!
It's about $6.50 a yard. You'll need about... 10 yards or so...
Save some money and use polyester resin. It'll melt your foam and be a disaster. (Use epoxy.)
KennethW wrote:I have build a foamie with canvas and paint. I think it is easier to work with then glass and resin. I feel the canvas and paint (PMF) work better as it is flexible. Fiberglass is hard and if it flex it cracks.
Sent from my Moto G (4) using Tapatalk
I think you misstyped. You told me to use polyester resin and it will melt my foam, then use epoxy. I assume you meant DONT use polyester resin and USE epoxy. Is that correct?
tony.latham wrote:I think you misstyped. You told me to use polyester resin and it will melt my foam, then use epoxy. I assume you meant DONT use polyester resin and USE epoxy. Is that correct?
Excuse my facetiousness! Just make sure you use epoxy and not the cheap polyester because it will melt your foam.
T
Pmullen503 wrote:There is really no advantage to epoxy/glass over foam compared to canvas and glue. Having done lots of epoxy/glass (on boats over wood) and now canvas on a foamy trailer, I'd say the canvas is more forgiving.
jimbo69ny wrote:Does anyone know if I can use canvas and resin instead of fiberglass and resin? I know I will have to add many layers in order to make it strong so maybe some fiberglass, some canvas? I have no idea how canvas interacts with resin.
Speaking of which, how many layers is sufficient?
Pmullen503 wrote:jimbo69ny wrote:Does anyone know if I can use canvas and resin instead of fiberglass and resin? I know I will have to add many layers in order to make it strong so maybe some fiberglass, some canvas? I have no idea how canvas interacts with resin.
Don't use epoxy with canvas. You'll use LOTS resin! One layer of 6 to 10 oz canvas with wood glue is enough.
Maybe you don't understand why you are building a foamy in the first place: Cheap, light, and easy. To get that you'll have to tolerate the rougher surface finish that more easily dents (though it will self heal in sun.)
If you want a hard, tough surface, then build with plywood and cover with either aluminum or epoxy/glass.
