Postby HandyAtLeast » Thu May 05, 2011 5:01 pm
Share my pain:
The tape came off while the glue was setting. Half of the curve set and the other half sprung out. The half that set seems very strong and, with skin, would hold up as a hatch with no additional support, I think.
GPW, yes, compound bending. I thought about that yesterday when I was cutting the kerfs. I could have rotated it 90 degrees and cut more kerfs. I'd like to try that.
I make stuff, and it's all designed on Post-Its... the small ones.
HandyAtLeast
Images: 22
Postby GPW » Thu May 05, 2011 5:46 pm
HAL, it was a great Test anyway , and we know now that works ... :thumbsup:
Compound bending could lead to many different TD shapes .... Foamie Roswell anyone ... 8)
Postby mikeschn » Thu May 05, 2011 5:47 pm
GPW wrote: Foamie Roswell anyone ... 8)
I think that's a great idea GPW. I think that should be your next build... :thumbsup:
Postby mikeschn » Thu May 05, 2011 6:35 pm
HandyAtLeast wrote:Share my pain:
It look like your method works. You could always tweak your profile with a jig, or a couple band clamps tightened around a couple ribs.
P.S. I'd really like to see someone play with it in 3 dimensions like you suggested.
Postby GPW » Thu May 05, 2011 7:29 pm
Mike , I edited everything I even thought might be controversial, objectionable or suggestive in any way ... I'm still a little confused about what ... :?
Bending it in a compound curve really adds a new dimension to this huh??? I've bent thinner foam (1/4" ) in the past to many interesting shapes , but being able to bend the thicker material really makes something like a Roswell or jelly bean very possible ... Have to be done in sections , but that's no problem with the foam ... Best thing is if we can't bend it we can just glue on a block or multiple layers of foam and just carve/sand away till we get the shape we want ...
I'd like something like a Big bumper Car ... (still on with that idea :roll: )
Postby pat g » Thu May 05, 2011 8:49 pm
Glad to see this thread continue. Very informative stuff. HAL and Gary Thanks for sharing your tests. I got to the store and started a build today. I'll start a build journal to show progress.
Thanks for all the advice!
Pat G :thumbsup:
pat g
Images: 122
Postby eaglesdare » Fri May 06, 2011 6:18 am
once that curved part of foam is covered it will hold. i do not think you need anything in the scored parts. or is that word suppose to be kerfed? i did not fill in the cut sections. started to , but there were too many and said the heck with it. so i just covered with full t2.
i think as this thread started and gpw beat the dead horse with paraphasing here, but the strenght is in the skin. the foam just holds it in place.
do i have that right gpw?
that piece of foam that bend back, will stay in place with a support. i personally do not recommend using spars made of foam, so using the wood and then attaching the curved parts to the wood will work. then the skin will hold it all together.
also i just noticed on my last pic i posted here, you can see that screws were used. we just screwed right thru the foam into the wood. covered with canvas, i doubt anything is going anywhere.
Louella
May the foam be with you.
eaglesdare
Postby eaglesdare » Fri May 06, 2011 6:24 am
GPW wrote:Mike , I edited everything I even thought might be controversial, objectionable or suggestive in any way ... I'm still a little confused about what ... :?
suggestive? what did i miss that had to be cleaned up?
Louella
eaglesdare
Postby eaglesdare » Fri May 06, 2011 6:25 am
pat g wrote:Glad to see this thread continue. Very informative stuff. HAL and Gary Thanks for sharing your tests. I got to the store and started a build today. I'll start a build journal to show progress.
Pat G :thumbsup:
your build is looking good. what are you going to cover the outside in? canvas?
Louella
eaglesdare
Postby GPW » Fri May 06, 2011 6:33 am
Eagle , you got it Right !!! Better that right !!! :thumbsup: You're camping already !!! :D
Now with so many innovations going on at the same time ,it's difficult to pick just one thing that works ... It's just another building material and it's How you use it !!! With so many great minds working on this , I'm sure things will develop in a most positive direction ... the more of these we build , the more we learn ... :thumbsup:
Pat , anxious to see what you come up with ... ;)
Postby eaglesdare » Fri May 06, 2011 6:51 am
http://tnttt.com/viewtopic.php?t=43987
that link is to pats build journal. he has started.
Louella
eaglesdare
Postby Steve_Cox » Fri May 06, 2011 6:58 am
I just read this thread for the double entendres GPW, always hoping you can do a triple which is extremely rare in forum land. :D
Today though was different, I had a vision of how to make the top corners of a bread loaf type camper in foam. Now to experiment with the kerf cuts to make the perfect 1/4 ball radii.
Steve_Cox
Images: 196
Postby pat g » Fri May 06, 2011 7:48 am
Hey Steve,
Would be cool if you get the kerfs figured for a 1/4 sphere!
I plan to use the 2 inch foam on the roof and kerf cuts to make my radius. My front radius is 24" and the other curve is pretty gentle. Should not be a problem. I'll let you know how it works out.
Gotta work on my truck today so may not get much done on my build until Monday.
Pat G
pat g
Images: 122
Postby eaglesdare » Fri May 06, 2011 7:48 am
i asked hubby if tomorrow before we do anything else, if we could weigh the foamie. he said yes. he wasn't thrilled, but he said yes. so hopefully tomorrow we will know that answer to the question.
Louella
eaglesdare
Postby GPW » Fri May 06, 2011 8:53 am
THANK YOU Eagle !!!! (and Hubby) :thumbsup: :thumbsup: :thumbsup:
Steve , Cool idea !!! Just another great design element to add to the knowledge base... 8)
Pat , I'm using 2" foam for my roof too ... that's pretty Stiff, not very Hard to Erect a strong structure without the Wood ... Eagle used the thinner foam ... hence the flimsy Performance issues ... But if you Feel you need the extra Enhancement , then go for it .... Stronger is always better ... and the extra added weight is probably not much a concern ...
