bonnie wrote:What would I use for the vent? I have space bags and could use those for smaller items, but would build the larger ones as Glenn has suggested.This could be really fun. Especially for decorative items, like doors and such.
linuxmanxxx wrote:I've been contemplating how to give a good press while on camper and come up with the idea to take a deflated air mattress place over the glued surface with many straps around and have the straps with a little slack and simply air up the mattress and press the surface evenly.
I've been using 3M 30NF neoprene contact cement to stick my foam to my luan and it sticks like crazy. I had to do some circle cutouts for vents through the luan and foam and I cannot pull the foam off the 4" circles at all and this was just putting the luan on and pressing with hands to flatten no vacuum or air press used. A gallon is plenty enough to do your walls and a tip is go to harbor freight and get the cheapest HVLP sprayer you can find and apply it that way and you will love life. Water based so no toxins or nausea during application. I did add tight bond 3 lines on my 1x2 runners just for insurance for the wood bonding and believe me its all stuck for many years to come.
Its rated foam safe and takes roughly 30 min on avg to flash the water off and be ready for the contact application. Used it to stick my aluminum to my luan as well.
Yes you coat both sides and thin enough to spray from a gun so coverage is very good. Get the green one so you can see how well you have it laid on and once it goes from a lime green to dark green its ready to contact together. Go to an actual fastenal if you have one and they will quote a much better price in person than online.Larry C wrote:Steve, that looks like the ideal product, but like ALL 3M products, it's pricey. $136 gal. I will have to think about that awhile. Do you use it like most contact cements applying to both sides?
Users browsing this forum: Google [Bot] and 11 guests
