where to get large amount of foam?
Postby GPW » Sat Jan 21, 2012 9:24 am
Eagle ,around here the oil industry uses giant blocks of beaded foam for flotation , temporary buoys , and floats ... Like 6’X6’X6' ... all with a hole through the middle to attach a line ... we see them regularly in oilfield company lots ... usually pretty beat up by the time , but we know the foam at least comes that big ... they’re Not laminated, just one Big piece... Would be FUN to get a couple pieces of this , glue them together and start carving .... but it could get Messy !!! :o
From previous experience with salvaging foam , once you cut off the weathered surface , the inside foam is like brand new ... :thumbsup:
Re:
Postby bonnie » Fri Feb 24, 2012 7:44 am
Finally got a call back. That 4x8x20" foam chunks are from a marina. If I load 'em I can have fewer than a truckload for the same price. Question. How much would a chunk of foam that big weigh? I'm thinking about buying four. Then I need to rig some sort of cutting slide as I don't have a way to make a gravity cutter -- not enough headroom. Unless it would work on an incline?
I'm hoping to get about 5 usable 4x6 or so pieces out of each chunk. Do you think that's being optimistic?
Now I just need to make plans for the road trip. :twisted:
Remember, the turtle won. :)
bonnie
Images: 107
Re: where to get large amount of foam?
Postby swampjeep » Fri Feb 24, 2012 8:27 am
I remember seeing a guy cutting 3" thick down to 2 pieces about 1.5 thick, had a nice set up where you push the piece thru, I'll have to see if I can find that for you.
swampjeep
Postby GPW » Fri Feb 24, 2012 9:07 am
Actually it’s pretty easy to slab out a block ... you need a table and a hot wire elevated to the cutting height ... easily done with scrap 2X4s and some clamps (do we need a pic) ... a temporary cutter than can easily be disassembled and returned to the scrap pile ... I’d LOVE to find some big blocks ... been looking around here , nothing yet ...
Postby Treeview » Fri Feb 24, 2012 10:42 am
I've used this mega search to find many things, including insulation:
http://www.searchtempest.com/
Treeview
Images: 30
Postby swampjeep » Fri Feb 24, 2012 12:21 pm
GPW wrote:Actually it’s pretty easy to slab out a block ... you need a table and a hot wire elevated to the cutting height ... easily done with scrap 2X4s and some clamps (do we need a pic) ... a temporary cutter than can easily be disassembled and returned to the scrap pile ... I’d LOVE to find some big blocks ... been looking around here , nothing yet ...
the one I seen was like this but with rollers right by the wire to keep the foam on the table and hopefully get an even thickness, but yes, pretty simple use of the hot wire.
swampjeep
Postby Treeview » Fri Feb 24, 2012 12:36 pm
Any links to these cutters? I've seen the basic concept. Its nice to see how people haves solved specialized problems like 'resawing' foam to the right thickness.
Treeview
Images: 30
Postby swampjeep » Fri Feb 24, 2012 1:22 pm
found the thread I was thinking of, no rollers, but it uses a bar to hold the foam down as you push it through.
http://www.expeditionportal.com/forum/threads/58926-POD-Homebuilt-foam-core-fiberglass-skin-pop-up-camper-build-thread/page2
swampjeep
Postby Treeview » Fri Feb 24, 2012 1:35 pm
Yes...now I remember!
Go to post #43 for pics of his resaw setup!
Treeview
Images: 30
Postby GPW » Fri Feb 24, 2012 10:50 pm
Wow!!! Post 45 says it all about slicing foam details ... Glad to see somebody else building with Foam ... :D
Looks like good solid construction too ... 8)
Postby bonnie » Tue Apr 10, 2012 8:08 pm
Those 4x8 by 20" blocks I found are old dock floats. Owner says they weigh around 200lbs each. Too heavy for my project. :thumbdown:
bonnie
Images: 107
Postby SteveW » Tue Apr 10, 2012 8:23 pm
That thread was the one that really got me interested in using foam for my build.
The build is on.
SteveW
Postby bonnie » Tue Apr 10, 2012 8:51 pm
Me too. :lol:
bonnie
Images: 107
Postby GPW » Wed Apr 11, 2012 6:42 am
A 4X8X20” Foam block should weigh ~ 100# Maybe he just has it wrong ... :o
Postby KCStudly » Thu Apr 12, 2012 3:16 pm
Or maybe they are water logged?
