Trog , aside from the dulling of the cheap paint , it’s just fine ... Inside , dry as toast ... the outside pretty much healed itself from that Most brutal Hail storm we’ve Ever had
... (Blu-Foam) ... No leaks , no worries , and due to a well sealed door , no little critters inside ... The window hinge does need replacing as it was a cheap ferrous metal one from the local ironmonger (rusted
) ... screws too ... I now have a proper Aluminum hinge and SS screws to replace it ...
Aside from that I need to paint the HF trailer frame ... it turned pink in the sub-tropical sunlight (we’re the same latitude as Cairo , Egypt ) , a tin of RED Rustoleum awaits the task ... Other than the above mentioned, everything is still “ sound as a pound” ...
Once I get the FoamStream all finished , I’ll get back on the little one and do a total re-paint ....
with Good paint this time ...
So far , the local storms haven’t appeared , giving us more time to work on both of these ...
Note: We’ve never (not Ever) had a trailer before that went two years without having to do
anything to it ... I’ve never even washed it ...
The daily deluge does a good job of that ...
Foamies do last !!! No question of that !!!
Contact cement sounds a bit pricy eh ?
We’ve had great Luck with TB2 over foam (not so much so with "the Gripper” )... that canvas stays attached ...
No use painting TB2 over the already attached canvas... Primer is the way there , then a Good Latex Exterior paint on top ...
