KCStudly wrote:Just don't get caught running it w/o reg. That would negate the whole cost saving effort.
You seem to be plenty knowledgeable and catching on quickly; I'm sure you know how to step drill those holes starting with a center prick punch (transfer punch is preferred) using plenty of lube and nice sharp drill bits... slow speed, make chips not smoke, right?![]()
I've got temp plates already, so that's not an issue.
I forgot about the center punch though. I have not actually drilled much metal before. I remember my dad drilling some metal once, he did high speed and low pressure, don't think he step drilled...took a while. And the biggest problem...I need a set of metal drill bits...guess a trip to HD or Menard's is in order, unless HF's drill bits are actually worth anything for drilling metal.
Actually, it's a good thing you commented, guess I better review drilling through steel.
