cpowell243 wrote:OP287,
I think I will be fine with the dinette. Gary and I have mapped this out - Gary using sketchup - we will have to crouch slightly to get into the seated position but will have plenty of head room in the seated position. - helps that I'm 5'7" and my wife is 5'5" - first time that has been an advantage.
Your 2nd comment re: stability is a major concern. My plan is to attach a curved sheet of ply maybe 2" wide around the interior of the hatch and glued my spars to the top of the piece - will add gussets if needed, but this would require the hatch to rise up above the box a little higher, thus raising the entire profile.
I'm also planning to use 1 1/2" X 2" frame that will sit between the polystyrene wall pieces at the hinge point. These vertical frame pieces will be attached to the spar the hinges the hatch with metal angle brackets. Sound any better???
cpowell243 wrote:Since I haven't to worked with canvas/glue skin, I am uncertain as to how much protection it provides to the edge of the plywood floor pieces. Is this a concern or can I dispense with the pieces on the outside of the plywood?
Other comments/suggestions?
