canvas drop cloth without a seam in the middle?
Re: canvas drop cloth without a seam in the middle?
Postby GPW » Fri Jul 17, 2015 5:35 pm
Seems only the cheap drop cloths have all these imperfections. anyway .. Spend a few coins on the good stuff , which if you catch it on Sale is even Cheaper than the drop cloths which only appear to be a bargain ... :o
Postby KCStudly » Fri Jul 17, 2015 7:15 pm
Hmm, :thinking: that diagonal weave might be a good thing for wrapping corners, kind of like bias tape. I wonder. :thinking:
Postby dales133 » Fri Jul 17, 2015 7:39 pm
Both of these fabrics were from a specialist fabric store and pretty high quality but at $10 a broad loom (1.5 merers wide) meter is cheap for here.
There is a canvas store I can get some from but it's $25 a broad loom meter.
I'll try to take some pics for better explanation today but basicly the diagonal weave is raw cotton canvas but similar to the coloured canvas used by high end tent manufacturers
dales133
Postby Fred Trout » Fri Jul 17, 2015 8:01 pm
ukewarrior wrote:When you sand the pills off, I'm assuming that the underlying weave of the fabric is still in place, correct?
in other words, does this create a hole in the canvas?
No hole in the canvas but the individual threads that have been pulled may be severed by the sanding. This has no impact since the entire fabric has become one sheet of fabric/foam/PVA composite and can not unravel
Fred Trout
Postby GPW » Sat Jul 18, 2015 7:29 am
" the entire fabric has become one sheet of fabric/foam/PVA composite and can not unravel” .... The Key to becoming a workable outer skin ... :thumbsup: 8) ;) :beer:
Postby dales133 » Sat Jul 18, 2015 7:40 am
Thank you Mr trout.
My build is neither conventional nor "foamie" but regardless every now and then I need to check I'm not crazy :)
dales133
Postby Mary C » Sat Jul 18, 2015 8:52 am
Where I found imperfections in the canvas I put extra glue and sanded smooth then with gladden gripper it filled in the "holes" in the weave. If I had been a perfectionist I would have put on another coat of gripper.
Mary C
Mary C
Images: 473
