Camp Capsule Foamy
Re: Camp Capsule Foamy
Postby Mary C » Thu Dec 03, 2015 8:17 pm
Awsome build, I am so impressed. It really is an achievement to build and get the
pictures on the forum. :applause: :applause: :applause:
Mary C.
Mary C
Images: 473
Postby ScottE » Thu Dec 03, 2015 9:17 pm
Thanks All for the Kind Words!
Anything is possible, if you don't know it can't be done!
ScottE
Images: 105
Postby Ned B » Tue Dec 08, 2015 4:28 am
What??? Where has this been hiding? Great job & welcome to the foamie side!
Ned B
Postby ghcoe » Tue Dec 08, 2015 9:04 pm
Looks great. Good job. :thumbsup:
George.
ghcoe
Postby ScottE » Sun Feb 07, 2016 8:14 am
Update: Made bathroom capable of using two types of portable toilets as some California state campgrounds insist on "tank" type toilets, though we prefer the bag type PET toilet and no dumping139209139210139211
View of medicine chest in bathroom139212
ScottE
Images: 105
Postby ScottE » Sun Feb 07, 2016 8:18 am
Made front cabinetry over dinette with recessed LED lighting on both sides on top of windows and under center cabinet, so light level can be adjusted for the mood... 139213139214139226139225
ScottE
Images: 105
Postby ScottE » Sun Feb 07, 2016 8:21 am
Building the countertop out of left over Pergo flooring with my stainless steel buffet pan sink139220 More recessed LED lighting installed under kitchen top cabinet 139218139219
ScottE
Images: 105
Postby ScottE » Sun Feb 07, 2016 8:27 am
Making a heat shield for the countertop from one of those lightweight camp stove wind shields, using wood to secure folding sections. This will be mounted under "lips" on the backsplash to prevent any damage to the foam wall.
139216139215
The closets and bathroom accordian door can be seen here
139222139217
ScottE
Images: 105
Postby ScottE » Sun Feb 07, 2016 8:31 am
Another view of the kitchen cabinets and power port for USB charging and cigarette lighter power
139221139223
The kitchen cabinetry and the thru hull fitting for the gray water tank can be seen here
139224139228
The gray water plumbing was simplified by using a section of flexible PVC from the fitting to the gray water inlet
139227
ScottE
Images: 105
Postby GPW » Sun Feb 07, 2016 8:41 am
WOW !!!! That’s really AMAZING !!! :thumbsup: 8) :D ...
Postby ghcoe » Sun Feb 07, 2016 9:36 am
George.
ghcoe
Postby OP827 » Sun Feb 07, 2016 11:40 pm
Do you mind to share how did you make hard points for your cupboards attachment to foam wall and how is it working?
OP827
Images: 405
Postby ScottE » Mon Feb 08, 2016 8:25 am
The hard points for my cabinets are embedded in the sides and ceiling by routing (or melting) out 3/4" deep pockets to match the blocking being used and then glued in place with Gorilla Glue.
139249139250
The blocks were held in place while curing with duct tape and push pins, in some cases.
139251139252
I found that setting the depth of my router to allow for the blocking and space for glue was best set up and tested until I found the level that would make flush supports. 139253
ScottE
Images: 105
Postby ScottE » Mon Feb 08, 2016 8:39 am
I also found that building the cabinetry into the walls was very strong when planned as part of the framing.139255
Grooving for embedding frame pieces was done with a router or the old HF soldering iron grooving tool. 139256139257
The cabinetry also strengthens the structure of the trailer when cured!
ScottE
Images: 105
Postby GPW » Mon Feb 08, 2016 12:38 pm
QUOTE: “ I also found that building the cabinetry into the walls was very strong when planned as part of the framing”... “ The cabinetry also strengthens the structure of the trailer when cured!”...
ScottE , that ’s Brilliant , and just about the only thing that’s yet to be fully utilized as part of the design itself , until now ;) ... cabinets as an integral part of the structure ... storage and support ...That’s just gotta’ be Strong !!! :o
