vigilant1 wrote:About the raised center section of the roof: What is your reasoning for that (instead of making the whole cabin 75" high?). It will be more complicated to construct as shown (two extra corners per wall), and not as strong (no direct load path from wall to wall). Also, those top corners in a "regular" trailer are handy for cabinets/storage. I've considered a design like this, but I haven't actually stood in one. My concern would be that, with my head up in that box, it might feel a bit "tight" (there's nothing to see except stuff below eye level, possibly requiring stooping down). And, I might be smacking my noggin on those edges (esp when bumbling around at night) resulting in salty language.
Anyway, something to think about.
Mark
It was for me, a way to give a small standing area inside the camper, while keeping most of the camper shorter than the wheelbase is wide. The trailer I am building on has a (roughly) 72" wide wheelbase, and a deck height somewhere around 20", and if I build the whole camper 75" high, that will give me a final height of roughly 8', on a 6' wide wheelbase. That to me, combined with building it light, seemed to be pushing beyond the limits of stability when traveling during windy weather, or even being passed by 2 large trucks timed just right, on either or both sides. I think if in the future I build a larger camper, on a 7' wide wheelbase, then I would certainly build taller all around.
As far as the trolley top, meh.. really I always thought they seemed neat. It was a way to reduce the wind drag a bit. I am also hoping to install my vents on the sides of that trolley top, instead of on the roof. Perhaps non-traditional, perhaps using 12 volt muffin fans with a hand crafted vent space, and some sort of cover over the outside to keep rainy weather out.
I still have not decided on windows. The door will be hand crafted. I think one window up toward the front may also be an emergency exit window.
Our tow vehicle for this camper is an old but trusty Dodge Grand Caravan, now approaching 300,000 miles. Probably broken in at this point
LoL Anyways the camper as designed really tucks in well, right behind the van, with only the trolley top really protruding up a lot higher than the van's roof. The rest of the camper, both width and height, should allow air to flow pretty well aerodynamically from van on to around the camper. The nose cone side angles arent optimal , and may even add a bit of side turbulence. I'm not well versed on aerodynamics, I know the most of the drag will come from that flat back end. But still, the lines flow well with the van, the trailer tire's footprints follow right in the van's tire prints, the van is also 6' wide, and the roof of the van is 6' at its highest point, tapering back to around 5'6" height at the rear hatch.
