Biggest foamies?
Re: Biggest foamies?
Postby rowerwet » Thu Jan 21, 2021 11:19 am
Mine is 6x13 with a flat plywood roof, supported by 1x3 spars on edge. I keep the tear parked nose or tail high for drainage. I plan on creating a standby out of it someday, with a bowed roof to not have to think about draining
rowerwet
Images: 521
Postby Socal Tom » Thu Jan 21, 2021 11:43 am
I would think that if you sandwich a wood "stringer"( like they do with surfboards) you will probably be ok.
https://youtu.be/qNHWbRV432s
Socal Tom
Postby Terra6 » Fri Jan 22, 2021 12:05 pm
Trick question.
They're building foamie houses and buildings.
If you include SIPS panels.
Basically, like any living thing, reinforcing structure frame required the bigger one builds.
Foam only seems 4x4x8 2 inch XPS is reasonable unsupported or unframed if that is what you're getting at.
Larger if skinned on both sides.
On the road to Shambala...
Terra6
