2nd Teardrop. a Foamies tale
Re: 2nd Teardrop. a Foamies tale
Postby ghcoe » Tue Aug 18, 2020 6:47 pm
Not sure how rough of a road you are planning to drive, but it is good practice for true off road trailers to keep the wheel distance the same as the tow vehicles. Makes it a lot easier to navigate through the rough stuff.
George.
ghcoe
Postby Wolfgang92025 » Tue Aug 18, 2020 8:16 pm
George,
The Colorado track is about 6'4" and the Woodie is about 6' 8". If the math is correct, the foamie track will be almost 7'.
If I decide that it needs to go narrower, stock trailer wheels vs the Colorado wheels & wheel adapter would give me back 4 or 5 inches.
Wolfgang
Wolfgang92025
Images: 660
Postby ghcoe » Tue Aug 18, 2020 9:08 pm
Wolfgang92025 wrote:George,
George.
ghcoe
Postby aggie79 » Wed Aug 19, 2020 2:59 pm
I'll be following this too! You had a fantastic first build. I look forward to your foamie construction.
Postby Wolfgang92025 » Sun Aug 23, 2020 11:18 am
So, While I was trying to work out some detail about the plan/design, I used some insulation to play around with to see what could be done.
Couple of different shapes
Surprised how tight a radius you could make and how strong it was just covered with thin paper stock
163027
163028
Next I glued some bed sheet material on foam. Half of it was over Primer, half over raw foam. Results were about equal.
163013
Did the same with gluing down a piece of 1/8 in ply. Turned out to be pretty difficult to remove
163014
Last test piece was 1/8" ply yo foam with Great Stuff foam. Man,that really works well.
163015
Once the design was close,I figured out that I would need about 14 sheets of insulation for my build.
The big place in Utah for want/sale adds is KSL. On occasion I would see adds for 2" foam.
Found a guy that was selling 4*8 sheets for $20. Bough all he had(10 sheets).
163029
Wolfgang
Wolfgang92025
Images: 660
Postby ghcoe » Sun Aug 23, 2020 12:42 pm
Good price on the foam. About $10.00 more economical than local retail here.
George.
ghcoe
Postby Terra6 » Sun Aug 23, 2020 5:35 pm
More foamie fun :thumbsup:
On the road to Shambala...
Terra6
Postby GPW » Mon Aug 24, 2020 3:53 am
https://www.youtube.com/watch?v=5WVKttqb6HQ Bending without kerfing …. Stronger yet … ;)
Postby Wolfgang92025 » Sun Aug 30, 2020 12:23 am
Right around the time I got the foam, the temperatures in the garage started get warn enough to start construction.
Started with what I call the Nose Cone. Its all held together with an 1.25 x 0.1" spline, titebond II and a strip of an old bed sheet.
It took a couple of tries before I was able to get it all to fit the way I wanted and get the correct spacing.
Two pieces coming together.
163054
Now 4......
163055
Then 6
163056
Some left over scrap panels with the spline
163057
Closeup of the joint
163058
Wolfgang
Wolfgang92025
Images: 660
Postby GPW » Sun Aug 30, 2020 5:32 am
What a great nose !!! 8) :thumbsup:
Postby twisted lines » Sun Aug 30, 2020 6:51 am
Hope to see this one sitting still 8)
Racking up; And Rapin foam
twisted lines
Postby tony.latham » Sun Aug 30, 2020 9:32 am
Its all held together with an 1.25 x 0.1" spline...
Wolf:
How'd you cut the slot for the spline?
:beer:
Postby ghcoe » Sun Aug 30, 2020 10:33 am
If you don't want to use a wood spline you can take 1" XPS and cut it into strips. Cut a 1" spline channel and you have a tight joint and still using foam. Just some thoughts.
George.
ghcoe
Postby Wolfgang92025 » Sun Aug 30, 2020 2:53 pm
Wolf:
:beer:
Tony,
I have an older (35+ years) 10" Craftman table saw. The blade I'm using makes a 0.100" cut and the spline material is a cheap 3 ply plywood that happens to be ~ 0.105" thick. My garage floor to ceiling clearance is almost 12'. This allows me to stand a 2" piece of foam on end on top of the table saw to make the spline cut.
The fence is made out of some cheaper 12 mm Baltic birch and built in a box frame style with two 1/4" all-thread rods that I used a jack screws to take the bow out of the plywood frame.
Pictures of the fence
163067
163068
163069
For the nose cone I made a 15 deg cut deeper than needed on the long edges first for the splines to sit in. Then I cut the pieces to the proper width while the table saw was still at 15 deg. I would glue the spline into one side of the panel with Titebond II first and after a few hours glue two panels together with Titebond. I used a temporary support structure to hold it all together until the glue was dry.
Wolfgang
Wolfgang92025
Images: 660
Postby Wolfgang92025 » Sun Sep 06, 2020 3:10 pm
Next was starting on the floor.
The floor is three pieces joint together with splines using Gorilla glue. Before gluing the floor together, I cut a 2" x 1/2" rabbit joint around the perimeter to help fit the large panels that will form the body.
Once the floor was one big piece, I cleaned up the joints and did a rough sanding. Wiped down the floor with alcohol and painted it with Valspar Primer.
A few weeks earlier I had send away for some canvas samples. Settled on 10 oz 72" cotton fabric from http://WWW.Marsidian.com. If you only order say 5 yards from Marsidian, the shipping will be a deal breaker.
But, since I will need 20+ yards, a 25 yard x 72" roll was $102.10 delivered to my door in about a week. By my math that's just over $4 per yard. :thumbsup:
Comes in a nice big roll, wrapped up nice and tight. No seams or wrinkles, just roll out what you need and cut to size.
Sorry, but I did not take pictures before the canvas was put on.
163099
163098
Sides are next............
Wolfgang
Wolfgang92025
Images: 660
