No ribbon from Sunday either.
Um. I didn't get anything done on Monday night. Well I got about 5 hours of shopping for a new TV for the foamy but nothing on the trailer. My old TV is about to die.
Last night I finished inletting for the door frame and got it glued in. That all went rather uneventfully. I took some plywood scrap I had laying around and covered it in packing tape. I also took some 1x2 scrap and used them in combination to clamp the frame in place while the glue set. I wanted the frame as close to flush on the outside as possible. I put the plywood on the outside (packing tape side in) and the wood blocks between the door frame and the clamp on the inside. Thus preventing my clamps from crushing any foam. Miraculously given all the gorilla glue mess I had going on nothing was glued where it shouldn't be. Also the door fits really flush to the outside of the trailer!
I had a learning experience too. Not the good kind. So while doing all this with a bottle of brand new gorilla glue ( I forget how much stiffer it gets when it's been open a while
) I had a lot of ooze/drip coming down from the top of the door frame. This resulted in me getting gorilla glue on my face and a fair bit of it in my hair
. (I forgot to wear a hat.) So then I went to find the acetone to clean up all the gorilla glue... and we were out.
So I tromped down to the cabinet where we store all the solvents.... I found some brake/carb cleaner. I tried it on my hand (where I had gotten gorilla glue after taking off my gloves and checking out my hair). It worked fine. so I then went after my cheek and chin... worked there too. (but it was starting to burn).... also the house smelled TERRRIBLE. I ended up hopping in the shower with the carb cleaner and using it to get the gorilla glue out of my hair. There were a lot of fumes.
I then used a LOT of aloe gel to solve the chemical burns on my face and scalp. An hour later I went and washed my hair out one more time before I went to bed. I still smell like carb cleaner. On the up side I still have all my hair. Nothing hurts! and um.. my door frame is glued in and looks great!
Laura
