It's only 92 here, so I went out to the garage to try and lift the roof.
I can't lift the roof by my little old self.
Makes me want to
I can't get to the window parts to remove them unless I can get the top safely lifted and supported. No
either. Might have to make and test out my electric threaded rod lift sooner rather than later.
Though on the upside, that means the lift will definitely be mechanical/electrical.
OR, take a saw to the roof. Which I may yet do. I was considering measuring down 11" to the very top of the windows, marking the line and cutting the bottom of the side walls away. The windows are plexi and shouldn't suffer too much from the drop.
I'm still pondering what to do with the front wall/window. Thinking I might be able to cut it away from the wall without destroying it.
So, for those of you who have hacked up fiberglass and such, could I do that? What would I use? Jig saw, my 2x4 saw? Dremel with cutting blade? Should I put the tie down strap back on to keep the top from shifting as I cut?
Very much ready to take a bath and go to bed. But I think I've talked myself into hacking the roof apart while it sits on the bottom part. Sigh.
