Despite not having much to report, let’s get caught up.
On Monday I pulled the big white kerosene heater (Karl’s Kero-Sun Omni 105) apart to change the wick and found that I had gotten the wrong one. I hadn’t noted the Type letter (‘N’) so when the guy at the hardware store said there were 4 out of 5 letter types that did not have pins, and only one that did, we figured the odds were with the ones w/o pins. We were wrong. Anyway, I had spent a good deal of time “consulting” with Karl on the pizza trailer (translation: BS’ing), so it was getting late and that’s all I did.
Wednesday I had errands, including exchanging the wick for the correct one (in the other direction to Mecca), and stopping by the house for the can of poly that I had forgotten to bring with me; more BS’ing; rebuilding the heater; and done.
Tonight was more errands; bank, refill kerosene can, and renew CCW permit… fortunately all along the way. When I got to the shop I gave Karl a hand handling some pieces of sheet steel in the shear and break (he’s making a large hydraulic tank for a customer; about 45 gallons (?)).
Finally I got to the build. I have struggled with the option of sealing the wood that will eventually have foam and/or canvas glued to it, or leaving it raw for best adhesion and relying on the glue layer and final paint job to seal out the weather. What I decided to do was use the mix along the edge of the ceiling skin and end grain of the spars, but leave the rest to be sealed with the adhesive and glue. Since the edge of the ceiling ply will be recessed under the edge of the ceiling foam (the gap to be filled with GS latter) it would be better to do this before attaching the foam.
Weather was wet and rainy, but warmer, so I pulled the rest of the dry fit foam off of the roof and mixed up a pot of 50/50. Here I have brushed the edge of the ceiling ply where it meets the wall, the ends of the spars, and about an inch or two onto the top of the ceiling where the screw holes are that hold the ceiling to the walls (Yvette stopped by to check on my progress).
I had already attached the foam on the front wall to either side of the locker bump out, but was able to run the chip brush down the groove (where the GS foam will be added later) and saturate it pretty well. While I was at it I swabbed the recesses for the side marker light wiring pockets at all four corners.
Once I had made it all the way around, I did another lap with a second application, essentially wet on wet. On a roll now, I went ahead and slapped a coat on the side door seal flange; the outside face, inner edge, and edges of the two layers of ply spacer for the flange. I left the cedar part more or less raw for the glue where the canvas will wrap into the jambs.
And that’s the name of that tune for tonight.
