Door Hinges in Foam?
Postby GPW » Sat Oct 15, 2011 7:44 am
Mel , honestly , the reason I started building was because I was so unhappy about the way the “Big Boysâ€
Postby gullywompr » Sat Oct 15, 2011 3:32 pm
I'm not sure how well this will work with canvas/glue (although I can't see why not), but one common way to get hardpoints in composite foam laminates is to drill a hole where the hardpoint is desired into one layer of the skin, but not all the way through and out the other layer. Then, create a cavity by removing the foam between the skins - a bent coat hanger in an electric drill is one way, and use a shopvac to suck out the pulverized foam bits. Mix up a slurry of epoxy and milled fiberglass and fill the cavity. Not something that would be practical for a full-length piano hinge, however.
Curtis Olson
gullywompr
Images: 7
Postby GPW » Mon Oct 17, 2011 10:31 am
Curtis , I believe that method was mentioned some time ago in the Big thread ... Surely an alternative ... :thumbsup:
