OK, monkeyed around with the heat gun on some 1/2" scrap this morning. Bottom line, it freaking rocks. I have a digital temperature gauge, and it looks like the foam hits 190 right around the time the skin begins to slightly deform. I jammed a piece of foam into a C shape (about a 15" radius" , held the gun about 4-5" from the foam while moving constantly (did the inside of the form first), then did the outside. I went over both sides at least twice to make sure that each inch got hit. Bottom line, the foam held it's form fine, with just a bit of deflection. Took all of 10 minutes. Messed with a wet towel for a little bit but it seemed to be more of a pain than it was worth.
Word to the wise, do this sort of thing outside because of the fumes. I'm going to put a fan inside the foamie when I do the inside of the hatch, have both doors open, hold my breath, and work a little at a time.
Not sure that it matters which side you do first, but doing the interior first seems to make sense intuitively. Take the compression load off first, then deal with the skin tension on the outside. Either way, I think this method is a winner.
I'd be interested to see how well this would work on 1" foam, but 1'2" foam works fine and I'm just going to laminate two layers together after they're pre-bent. All that's left is the hatch and finishing the doors for this to be functional. I still want to put fiberglass tape over all the spars and at every joint, but that'll probably be a January project once things calm down here.
