KCStudly wrote:If you are worried about aerodynamics at all the first worst thing to do is build up.
Well I am, however I think that I’m limited in what I can gain from it, I’m pretty committed to the height of about 2’. If I get the mock up covered with plastic and blow over I won’t do it. If I do do it I guess what I would like to know is how much changing the front angle from 45 will matter, should the point where the angle meets the roof be the highest point with it sloping back to the rear, or should I raise the rear and lower the front? I only have an inch or two to play with, so will that matter? Should I roll that point, kerf and bend? It would probably be tight since I would think I would need the front roof part fairly flat to get some form of skylight in there. I would rather not kerf, feel I got enough challenges.
Re: roof spars, the assembled strength comes from the inner and outer skins, so interrupting the inner skin by letting the spars interrupt the ceiling panel will not yield maximum strength.
I kind of guessed that but it is a kind of truss if it is all glued together isn't it? I don't know but would like to.
Better to have the spars sandwiched between skins.
The only reason I added spars was because of my build sequence. I wanted to install my ceiling ply before forming the foam arch over the top of it and the ply would not support its own weight. If I had built a form to build the roof panel over I may have been able to get away w/o roof spars, but that would have taken more effort and lumber to build the form. It was just cheaper and easier, and more accurate to build in place using spars.
If you are building your roof panel out of foam and then applying a canvas ceiling skin after the fact, you might get away with no spars. The foam can surely support its own weight, especially if kerfed and arched.
mvankanan wrote:It seems that everyone uses some wood in the roof, are these structural? Since interior height is important to me, has anyone routed these into the foam, say ¾”, would this add to or decrease the strength? It would give a larger gluing area.
lthomas987 wrote:mvankanan wrote:It seems that everyone uses some wood in the roof, are these structural? Since interior height is important to me, has anyone routed these into the foam, say ¾”, would this add to or decrease the strength? It would give a larger gluing area.
Not everybody uses roof spars. Many don't use spars. My roof is spar free. I have set many moderately heavy things including my dogs up there. I haven't tried getting up there myself as I am not moderately heavy but quite heavy.
I'm thinking of perhaps only under the tie down points, I will eventually post something if/when I get that far
Also don't fear kerfing. It's not very hard and can make seam free sections.
It'll make me stronger?![]()
From my roof top hauling experience I would strongly suggest radius-ing all your corners. Sharp edges make a lot more noise in the wind.
GPW wrote:Just a drawing of an inverted top idea .... any old Hot Rod body man could easily do it ,cut around the drip edge flip it and weld it back upside down with little tabs to the drip edge to support it all ... If it didn’t interfere with your interior headroom , it would give you about 4-6” of extra cabin height without being that much higher over the top of the vehicle ...You could even cut your hatch in the front so as to crawl up into the sleep chamber...
mvankanan wrote:...would you just run a router along the finished build before skinning? I'm not sure I see this in the pictures of the build's, but maybe I'm missing it, a lot of info to absorb.
mvankanan wrote:lthomas987 wrote:mvankanan wrote:It seems that everyone uses some wood in the roof, are these structural? Since interior height is important to me, has anyone routed these into the foam, say ¾”, would this add to or decrease the strength? It would give a larger gluing area.
I've heard this before, would you just run a router along the finished build before skinning? I'm not sure I see this in the pictures of the build's, but maybe I'm missing it, a lot of info to absorb.
Not sure I didn't mangle the quote thing again![]()
Thanks Laura
mvankanan wrote:I got the headliner out, I was a little bummed out because the cross ribs were in the way of my holes in the roof. I went and saw my car guy he said mike think about any van conversion when the take the whole roof off, where are the cross pieces? So now I’m a whole lot less worried and I’m going to just go for it. Bad weather for the next week it looks like; wish I had a big shop with a level floor.
As far as not worried about cutting into the roof, this frees up the design a bit, if I can move the entrance hole back, with a drop in panel to sleep on, I think I can change the build profile and lower the front height, and angle. I’ve been playing around with crawling in and out of the mock up with different heights, if the hole is larger I can get by with less height, at least in the feet end. Maybe a pop up part over my head?
It occurred to me that it might be a lot easier to bend tubing to fit the roof profile, I could then screw or bolt some plywood strips connected to the sides of the floor panel to the tubing, and the tubing to the roof. This might make it a lot easier to level. I wouldn’t have to be as accurate cutting the bottom of the ply strips, I could then wrap the canvas under the whole floor, and then set it back on the tubing and attach it. The problem would be in getting some kind of gasket for the tubing? Something like that slip on foam pipe insulation comes to mind but that wouldn’t be rugged enough. Anyone have any ideas for the gasket?
I’m thinking emt conduit for the tubing. More weight then I want, but that seems easier to fabricate? It would need to be u shaped two sides and the front, maybe one and a half inches so I will have more meat to attach the build?
I guess I will use titebond 2 to make the floor panel, 1” foam 1/8 luan top and bottom, wood around the edges to bolt thru. I’m planning to leave it solid and cut out the holes for the skylight and entrance later, I’m thinking I could cut the holes and then rout out the foam, leaving the ply and then glue in the wood strips around the edges of the holes?
Whatever I use for the wood edges presents a bit of a problem because the foam is a full inch, wood is only ¾” seems like I might want it a little wider for bolts? 5/4 on the flat is still only 7/8”? I’m thinking of gluing 1x3 together on the flat and then resawing that to get the full inch I need, I’ll end up with a 1 ½” x 1” piece. I guess I could try to find ¾” foam but I would rather have thicker, without the height constraints I would prefer 2”. I feel like I’m limited by what’s at Home depot 1” or 2” in full 4x8 square edge. Don’t want to get it shipped or special order for fear of damage to the edges and it’s only one sheet for the floor?
Getting the floor up on the roof should allow me to visualize what I’ll have to work with better as far as height. I have another wrinkle in that the jeeps a little wider below the roof in the back so once I get the floor up there I can get an idea of what I can do there. It is tempting to make the whole build a little wider than the roof but then I’m dealing with lift? Anyone with the engineering skills to puzzle me through that? It would be about 3-4” on each side? That might cause me to need more foam for the roof but then again I could angle that, say the bottom is 56” the top could still be 48”?
Thanks Mike
