loaderman wrote:Yes to do 84sf in 1000-1200lbs is not going to be easy. when you look at about 500lbs for the trailer alone that is only 5-700 for the rest.![]()
The Harbour freight type trailer is about 300lbs, but only 4 by 8 so not big enough. The 7' body would be too wide on that small a trailer.
Hmmm, cats?I need a van with more cat capacity!
GPW wrote:The intriguing idea of a “Utility” trailer is you can easily build a slide on/off cabin , and still have the use of the trailer ...
KCStudly wrote:So at 5x8 (?) that 500 lb (likely finished, but not loaded for camping) weight = 12.5 lbs/sq ft.
Good job GHC!
GPW wrote: The intriguing idea of a “Utility” trailer is you can easily build a slide on/off cabin , and still have the use of the trailer ...
Users browsing this forum: jgmahoney and 9 guests
