Whew! Finally back at it! Only under the weather to a lesser or greater degree for a month, that's all.
But anyway, there have been a couple developments. First I finished trimming down the innerspring mattress, and reassembling it with a 1.5" memory foam topper on it. I had to trim down two rows of springs from both the side and the bottom, which was (of course) more challenging than I thought it would be. But it was a part of the process that I got to do inside, in front of the TV with the big annual tournament for the video game I play going in the background, and a dog making herself *ahem* useful.
- Trailer 6-1.JPG (215.41 KiB) Viewed 1646 times
It's definitely a small bed! I think the shortness of it hadn't really sunk in, and I think if I were any shorter than 5'3" it would definitely be a problem, or if I were trying to squeeze another person into the space. But it's just for me, so I think it'll be fine. And when I did a dry run of the layers before assembling it, I almost fell asleep in the living room in the middle of the day, so that seems like a good sign as far as comfort goes!
And then today I was able to get a bit more done, as well. I got the front cap cut, so now all of the structural elements of the foamie are cut down to size and shape, and only need to be modified to run cables and incorporate the wooden additions (for doors, vents, hatches, skylights etc). For this I tried out the other hotwire tool off amazon that I found, and it was... interesting. It cut much cleaner by far, and with far, far less fumes. It didn't melt as much of the material as the hot rod does, either, so it's probably a fair bit more accurate. It can only cut four inches deep, though, so that's a bit limiting. Now that I've used this tool, I definitely see what KCStudly was saying about it leaving the surface potentially too smooth for proper glue adhesion... it leaves a very different surface than the hot rod! Makes for prettier and faster 45 degree angles, though, as you can see.
- Trailer 6-2.JPG (96.37 KiB) Viewed 1646 times
After that, I set about getting the holes cut out for the skylight and the roof vent, which leaves me with pretty much all of the big holes as such cut out of the foam in the trailer, which is relieving. But the big thing is that it left me with spare pieces of foam large enough to be able to do some tests of the different adhesives I'm considering for how I'll be attaching the fabric to the foamie!
The contenders are the Childers Lagging Adhesive that ghcoe found, TBII, and Glidden Gripper.
- Trailer 6-3.JPG (119.39 KiB) Viewed 1646 times
I wanted to test all three both so I can get a sense of what the application process is like, and how well it feels the three of them adhere, comparatively. I also want to be able to run a few flammability tests, as that particular worry would be nice to abate if possible. So... yeah. I was pleasantly (maybe) surprised by how goopy and thick the childers is... even if one of the other two wins out in my opinion, it may still be a good smoothing coating, for which it's also recommended. But we'll see how they fare when they've all dried.
That's it for the day, but finally glad to be moving again.
@duncam Thanks for the advise! I've been following your build as well, when you post updates, though I don't tend to post in a lot of other threads. I really like the whole pop-up concept... helps with the aerodynamics but gives you space to stand inside, but avoids all the low insulation and time consuming set-up pitfalls of regular popups. When I was a kid growing up in Alaska, my family had a super old, super heavy popup that we took all over the place. Some great memories in that.
Hopefully yours will have some too... with less velcro and invasive mosquitos who find their way in somehow!
My thinking on the second foamie that I'd live in more long term has evolved a bit... as has my idea of how long I'm going to spend in this one. I'm thinking it'll probably be a year or so before The Big One... but that hasn't stopped the obsessive dreaming. I'm thinking that I'm going to make it 6'x10', using one of those standard carry-on utility trailers as a base. That way I can put the door on the back, and use put little legs on the fold-down loading ramp so that it functions as a sort of front porch. For the inside, I'm planning on having one of the walls fold down, and having the bed in there, with the kitchen on the other side, and a large work area (I'm pretty deeply computer-based) in the front. Effectively, it would end up a 10x10 space, which I think would end up feeling quite spacious, but would still be pretty compact to drive with. The tentative name I've got in mind is 'Foamie 2: Fold-down boogaloo'. You know, not that I've thought about it or anything.
Buuuuut that's quite a ways off, yet. Gotta finish this one first! Good luck with yours... looks like it's coming right along! Excited to see it finished.
