Weather is still unpredictable. So, I worked on cushions. With 14 days of furlough without pay coming, I decided to change my color plan and use some upholstery fabric I had on hand. I have an old, heavy coffee table top that happens to be exactly the width I needed for my cushions, so I used it as a template.
The draw saw worked really well as a foam cutting tool. Also worked really well cutting flesh. I bled, just not all over the foam.
Small cut, but on the pad of my index finger. Healing nicely and reminding me it's there every time I hit it.
Here's two shots one side of the cushions done and placed in BUB for reference. For some reason or another, the backrest looks longer than the seat. I just think it's conformed to the cover better, as it's the first cushion I completed. Two more to go and I will have somewhere to sleep; and one more thing off the "to do" list.
I'm thinking the interior of BUB will now be either off white or a very light green. Not ready for paint yet, but getting there. Probably white so I can use the colors in other ways. I think the cushions came out a lot more spiffy than I originally thought they would.
If you notice the blue foam against the far wall, you'll have a hint of what the headboard/lift will look like. It's too tall and I haven't even begun that project in earnest, but I did get what I hope is the remainder of the parts this weekend.
I picked up a breakaway battery -- AGM 12volt, 5 ah at 1.5 amps. It does run the lift motor.
And I will be able to test lights as I wire them up. Since everything going into BUB is LED, I could conceivably use a couple of these little batteries and have my 12volt system rocking and rolling without the weight penalty of a larger battery.
I have one more weekend before Gall Bladder surgery and then I'm out of commission for a bit. I hope to use next weekend to fix the wall and maybe get to build a bit on the lift. I'm excited about it; if it works like it does in my head; it will be almost magic.
While I'm recovering and cannot lift stuff; I intend to work on the electrical parts and bits. At least testing things. This is so exciting to see the project actually taking shape.
