The Poet Creek Express - Foamie Hybrid
Re: The Poet Creek Express - Foamie Hybrid
Postby KCStudly » Fri Jan 01, 2016 3:22 am
dales133 wrote:how much more glass have you got to go(?)
Um, all of it. :R
But seriously, let’s think about that. Where do we go from here? Well it is all dictated by the 60 inch width of the cloth vs. the 64 inch wide cabin. I want to glass the sides first so that they are the bottom plies in the seam where they wrap up onto the roof. Each of the side layups will be two plies at 0/90 deg running the full length of the trailer tucking under the floor and extending up on to the roof/hatch/front at least 3 inches along each side (probably more like 4 inches).
I’m not sure how I will wrap this under the floor yet. I dread doing a flox corner along the bottom of the floor on both sides all the way aft of the rock guards, but I don’t want to radius the bottom corner of the floor so much that it creates a “butt crack” with the chassis tube radius. I need to look at this closer and see what I think I can live with.
Before doing the walls the hatch needs to be in place so that the seam lines between sides and roof carry thru to the hatch and are consistent… although that might not be such an issue if I fair everything well before paint, I just want it to be consistent between hatch and roof and as symmetrical as possible if there are phantom lines from the seams that don't get worked out due to imperfect body work. Also, I am leaning toward doing the flox corners around the side doors in order to keep those body lines crisp(er).
The fit of the hatch will have to be double checked and adjusted at the galley side walls as needed. I probably should have left a bigger seal gap between the bumper and rear edge of the floor. Before the bumper glass this was only a scant 1/16 inch, so the ‘D’-shaped seal will be over compressed, especially at the corners where the glass plies are doubled up.
The front and roof glass will be the full 60 inches wide overlapping the side wraps about an inch or so along each side of the roof (cabin is 64 wide) running at 0/90 from the overlap with the hatch hinge glass I just did, forward to at least the top of the front locker bump out. The locker and sides of the front wall will probably be handled separately, including filling in the row of pocket screws underneath holding the locker to the front edge of the floor.
Once the side glass has been trimmed and sanded flush to the door jamb flox corners, I’ll do the door frame/jamb areas up to the door seal flanges. The outer faces of the flanges will just get sealed with wet epoxy so as to minimize added thickness to the flange and affecting the fit of the trim seal.
Back at the hatch I have to fill in some dents in the foam that came from rocking it over lumps in the folded sheet that was supposed to help protect it from damage. At least one of the two hatch skin plies will be oriented with the strands running diagonally (“on the bias”) from the top to the bottom corner (about 45 deg); and will overlap at both the hinge and bumper glass that I have already done.
Then I’ll cut the hatch free again and work on the hatch seal rabbet along the outer edge of the galley walls. The flox corners on the hatch side edges are already filled so that side of the seal will just need to be sanded back even. Then I can use the rabbeting bit and router to set the proper compression on the seal by cutting the rabbets into the outer edges of the galley wing walls. Then that corner can be back gouged and floxed; then the area of the rabbet where the seal makes contact can be glassed up to the step (up to the point where it is inside of where the seal contacts the top of the wall edge... the seal will be adhered to the underside of the hatch).
The roof fan opening and hatch actuator switch recess are simple cutouts that just get sanded flush, and that is pretty much it for the raw glass work. After that it is all sanding, fairing filler (or high build primer), paint prep and paint.
Whew, and you all are wondering why this thing isn’t covered yet!
BTW, Happy New Year!!!
Back to the build progress: today (Thursday) the sun came out and it warmed up to the middle 40’s (low 40’s by the time I got up on the hill… still some remnants of piled snow there). That, combined with Karl having run the wood stove downstairs all day resulted in a loft temperature of 50 deg F. So it was good enough to do the license plate recess glass layup.
Recall that I had already set up the PMPP for two stepped plies of 6oz bias scraps around the ogee like border of the recess. Tonight I cut a couple more strips of no bias to infill the flat portion of the smaller ply. Then I mixed up a batch of wet and poured it out over both arrangements. Strange thing was that I calculated wrong, adding the two single plies together and then multiplying both areas times my formula for two plies; then rounded up for the wet out planning to do wet on wet. It was still only 3oz of resin, so I guess that mitigated the math error.
Anyway, I mixed that and poured it out in drizzles, squeegeed both panels out roughly and dabbed at it some with a cut down chip brush. There were still a few areas that hadn’t soaked it in all the way, and it still seemed plenty wet (which is when I figured out my mistake), so I scooped up some of the excess back into the cup and brushed that on the plate area of the hatch to pre-wet it. You can just see the faint outline of the wet area here extending an inch or so around the plate recess.
By that time the panels had soaked in the wet. My guess is that the glass, plastic and table were still relatively cold, so it took a little time to soak in (as noted in the West System info for cold weather layups).
About this time Karl came up to check in on progress and lent a hand taking some “live action” photos. Here I am with the plastic laid over the smaller panel, squeegeeing it out.
Then I cut that out, peeled the bottom plastic, and laid it in position over the larger panel. Here I am squeegeeing down the smaller PMPP before peeling the smaller top plastic off.
Next I laid the bigger top plastic down and squeegeed it. Then I freed that all from the bench and cut out the bigger outline; folded it in half vertically and made a snip for the marker light wire; folded it on the wire hole horizontally and made another snip forming a star for the marker light wire to pass thru; then peeled the back off (carefully making sure that all of the individual scraps stayed attached to the top plastic as I peeled it); folded it back against the plastic along the vertical axis and aligned the wet half while enlisting Karl to help pass the wire thru the hole, all while attempting to keep it aligned. Once the wire was thru there were a few slight adjustments (wet on wet is still tricky even with the PMPP), but I managed to get as much of it squeegeed down with the top plastic still holding it pretty much in position. The bubbles you see are pretty much all between the relatively stiff plastic and the top of the lamination.
After carefully peeling the top plastic off, nudging a few of the butt seams back together, and pressing everything that had lifted back down a bit I had this.
I little more stippling with the cut down chip brush and we got to here.
Yeah, there are some lumpy areas where the foam and spackle weren’t as nice as I would have liked, but at least the glass seemed to follow the contour reasonably well, and it will cure hard enough now to bodywork it properly.
Strips of plastic squeegeed down around the perimeter to flatten out any edge nubbies.
I didn’t bother trying to peel ply the seams in the field under the plate. I figured these wouldn’t matter that much since they would be easier to sand and fair in the flat; and if they need too much attention they can be ignored behind the plate.
There was a small area on the lower left side of the inside radius were the glass pulled tight from squeegeeing the plastic, and another area just above and to the right of the marker light that seemed to have a wad of glass strand pushing up, so I stippled it all down again with the brush.
Once everything seemed good I wiped the wires off with a paper shop towel and taped them up out of the wetness.
This was an attempt to show the effect at the wire pass thru and what I will have to try and trim up once cured. The top edge appears uneven and scalloped, but that is just the edge of the plastic peel ply hanging over the edge of the recess. The actual recess is not perfect, but it is better than it appears here.
And that is where I walked away for the night. Fingers crossed until tomorrow (Friday).
Postby dales133 » Fri Jan 01, 2016 4:48 am
even though i perposely fouund cloth that would cover my walls with floor and roof overlap (it took months of searching and ended up being one of the better products id looked at) i was close to being in your situation .
Are you going to feather out the seams so they are completly invisable or will they teligrapgh through to an extent?
what i am doing and you could do to disguise a visable join at the bottom and avoid the bum crack thing that i didnt want at all either! Is fit a aluminium strip along the edge of trailer to body join.
My undercarage will be aluminium and while it would be easier to do the bum crack thing by fitting the body after ,im covering all the lower portion of my cabin by about 1 inch with the chequer plate that clads the lower storage.
Not sure if it works for you but maybe a hard edge that overlaps the frame and glassed over if your blending it in or some kind of flashing
dales133
Postby KCStudly » Fri Jan 01, 2016 2:26 pm
On the overlap seams I do intend to fair them out, but I figure it will be easier to make them "appear disappeared" if the seam is consistent along the hatch and roof. On the hatch I will probably run the bias ply all the way around the radius edge down to the seal parting line. That way there will be 3 full plies along the vertical side edges of the hatch, adding a little extra rigidity to the hatch overall.
The idea of placing trim along the base to cover "the butt crack" would be a relatively easy solution, but I am trying to avoid any and all trim, and therefore any caulk that could break down over time. As it stands now I have the hatch hinge, the roof vent, the external hatch actuator switch, and the side door windows. If you count the TB there are a few more penetrations (shore power to the battery charger, solar charger and future 12v outlet for the hand held bucket shower/pump wand that I got for X-mas).
There will also be sealant around the edges of the rock guards, and probably at the fenders and wing table cleats... and all of the marker lights, so maybe a few more screw holes and strips of trim wouldn't be the end of the world. I'll consider that option as I work up to "the point of no return".
Postby dales133 » Fri Jan 01, 2016 6:12 pm
dales133
Postby OP827 » Fri Jan 01, 2016 6:45 pm
Your fiberglass work is looking great KC. As for trim and such, I am starting to feel that all trim on fiberglass skin can be built and added with more fiberglass, similar to what I did in my build with vertical weather strips for folding walls that were made of fiberglass. I feel that such trim is way more resilient to weather and appearance is looking much more integrated into fiberglass design lines. Just my 2 cents.
OP827
Images: 414
Postby KCStudly » Fri Jan 01, 2016 7:05 pm
Yes. All the while GPW's experience with his drip edge on the FoamStream is floating around in my mind. I don't want to create an upward facing seam or ledge for "stuff" to collect or seep in, but I also don't want to have a groove where "stuff" settles in either.
So many details.
Postby OP827 » Sat Jan 02, 2016 2:09 am
KCStudly wrote:Yes. All the while GPW's experience with his drip edge on the FoamStream is floating around in my mind. I don't want to create an upward facing seam or ledge for "stuff" to collect or seep in, but I also don't want to have a groove where "stuff" settles in either.
So many details.
KC, I am not sure I understand what do you mean above by a groove.
Will this idea on the photo work for you, maybe? Of course it can be made shorter for a drip edge:
This is what I am doing in my build.
OP827
Images: 414
Postby GPW » Sat Jan 02, 2016 7:42 am
My 2 cents ... The temporary drip edge has worked so well, we’re now thinking a drip edge of some sort should be included on every trailer .. at least in anyplace that rains ... My friends commercial trailer (hunting trailer ) down the street was declared a total loss when the floor membrane ( cheap plastic sheet under the floor ) filled with water like a great saggy balloon and rotted the floor out on the entire trailer ... what a mess, and it appears water wicked under the floor and collected in the “membrane “ ...drip edge of any sort would have prevented this ... now he has to buy a new trailer ( after just 3 years ) .... :frightened:
We learn as we build ... :thinking:
Postby KCStudly » Sat Jan 02, 2016 9:27 am
If you can imagine looking down the side of the trailer frame at eye level with the top of the side rail tube, you would see the radius of the square tube. Since my cabin will sit on top of the frame (walls do not extend onto sides of frame) that radius will form a groove under the floor. If I now put a radius on the lower edge of the floor to allow the FG to flow around the edge easily, you would get a sideways facing "butt crack" groove where the two radii meet.
I am not so worried about moisture getting in as the cabin will all be sealed in with FG wrapped under the bottom of the floor for a few inches, but dirt and debris might tend to collect there. I had hoped to keep the radius along the bottom edge of the cabin more like 1/8 inch so that it would form more of a shadow line, not a butt crack (or valley, or groove).
The dilemma, if you want to call it that, is that my plan is to finish the cabin in the loft all the way thru to final paint, then put it on the trailer. So to form a drip edge there now would put it in harms way during the landing operation and I wouldn't have a chance to check fit. On the other hand, if I wait to fit the cabin to the trailer and then mold a drip edge, it would mean doing final bodywork at ground level; perhaps even on the trailer. I don't think I want to do that work outside and it would be a conflict trying to do it in the steel shop.
The best two or three options I see are to: (1) keep the crisp edge on the cabin by bucking up and doing the flox corner ( :? ); (2) make a larger radius on the bottom edge of the floor to wrap the glass under and just see how it goes later down the road; I guess it would not look horrible if the two radii matched each other, plus the rock guard could be made to cover over the gap at the front and along the sides as far back as the doors; and (3) if (2) and stuff does tend to collect in the groove, I could add a screw on piece of trim later down the road.
So that being spelled out, I think the thing to do is take one of my test panels, put the appropriate radius on it, add a little glass wrap and clamp it to the trailer frame. It won't be the same as going down the road, but over the next few days or weeks while I continue doing prep it should tell me something. Maybe the butt crack joint won’t look so bad.
Now that I think about it some, there is a forth option. I could incorporate a molded drip edge into the scalloped color scheme that has been brewing in the back of my mind, and leave the bottom portion and scallop color to be done later. That would minimize the glass, body and paint work that would have to happen at ground level.
I think I (we) may be over analyzing this. Off to the build I go for a nice early start today. Hatch is going back on the cabin!
Postby OP827 » Sat Jan 02, 2016 12:47 pm
KC, thanks for explaining the groove. It may actually look ok though and if there is a bead of caulk in between the frame and trailer cabin, then the moisture will not be able to get to the plywood floor beyond the glassed area above the frame, if I understand it correctly.
OP827
Images: 414
Postby dales133 » Sat Jan 02, 2016 2:26 pm
One more thought KC as i will have a similar issue depending on how i finnish my subfloor..
You could use an aluminium t mould and sandwitch it with adhesive between the cabin and frame upon installation,im toying with this idea myself now
dales133
Postby KCStudly » Sat Jan 02, 2016 6:11 pm
OP, I plan to bed the cabin onto a bead of something, or waterproof welting when it gets set on the trailer frame, so no worries about water seeping under.
Dale, I think the sill T-trim would look great on your build, but probably not so much on mine where it would look out of place, IMHO.
Made a little progress today, and still have a couple of pics from yesterday to post, so I'll get on to that.
Postby Atomic77 » Sat Jan 02, 2016 7:34 pm
KCStudly wrote:OP, I plan to bed the cabin onto a bead of something, or waterproof welting when it gets set on the trailer frame, so no worries about water seeping under.
Not sure what your plan is for bedding the cabin... In my case I used a thick bead of Hysol. If you've never used it, it's pretty dang amazing. It's our number one go to for a structural adhesive on the race boat. You can bond dissimilar materials with absolute confidence and it's completely waterproof. I've seen things pretty broken up after a flip and it breaks everywhere except the Hysol bond. Sorry for the poor picture but this is how I bonded and sealed the wall cleats and wheel tubs to the flooring/frame.
Michael
"The Strength is in the Sum of the Parts..."
The Astroliner
Follow The Astroliner Blog Here!
Check out our YouTube video
Atomic77
Images: 309
Postby KCStudly » Sun Jan 03, 2016 10:16 pm
Thanks Michael. That sounds like good stuff, but I was thinking of using something a little more flexible; something that I might be able to cut with a wire if I ever have a need to separate the cabin from the trailer.
With the holiday I haven’t been killing myself on the build, but I did get a few hours of time in each day this long weekend.
Let’s get caught up on things.
Friday I peeled the plastic from around the license plate recess layup. The plastic is turning out to be a mixed blessing. Unlike proper Dacron peel ply, it doesn’t absorb the excess epoxy, so that can pool or wick to the edges. It does a nice job of keeping the ruffled edges of the glass cloth down, making them much easier to fair, if anything is needed at all; but, as you can see in this pic, it also prevents the epoxy from self-leveling, tending to create ripples that follow the shape of the plastic. Here at the top of the recess there was some flash.
At the lower left side of the recess taper there was some puddling built up.
In this case, because of all of the pieced together seems that needed sanding, it may have been less work just to sand the edges, than to have used the plastic in the first place. An advantage that it has over std. peel ply is that it peels off easily; whereas I am told that regular peel ply takes a grab and might even peel up some of the foam.
After sanding that flash, scrubbing the amine blush off, and working it all over with 100 grit to knock back the excess and work the seams down I got it to here.
There are still some lumpy areas from the substrate, some of the glass layers want a little fairing filler where they didn’t butt perfectly, and I had one small spot on the lower right that had a blister I had to sand back out (I think squeegeeing the plastic down pulled the cloth taught lifting it out over the inside corner)…
… but all in all I think it came out okay.
To get the hatch ready to go back on the cabin I needed to remove the plastic “diaper” masking from the underside. Where it was taped to the sides of the outer ribs it was bunched up enough that it would have interfered with the side walls. The tape seemed to be peeling off okay, despite the cold temps, and I figured that the poly on the ribs was good and cured, so I didn’t worry too much about it. Karl came for a visit and immediately pointed out where the poly had lifted in a few areas. ( :x ) I should have taken more care and warmed the tape with the hair dryer or heat gun. You can barely see the affected areas here just below the remaining blue tape (they look a little lighter).
Here’s a longer shot showing the hatch with the diaper removed, turned around on the bench again with the hinge ready to go back on (on the left).
I drilled thru the bumper skin to open the draw latch tab screw holes back up and reinstalled the tabs…
… and reinstalled the hinge.
Saturday morning Karl helped me lift the hatch into position and get the hinge holes lined back up again. Once a few of the screws were run back in it pretty much found its place and fit as good as it ever has.
I decided to try a different approach. I had been using a 1/16 inch shim to hold the bumper out from the back of the floor, but that would have over compressed the seal. My intent had been to rabbet out a seal groove on the lower rear edge of the floor, under the aluminum wear edge that is inset into the top rear edge of the floor; but my thought now is to change these shims to 3/16 inch thick (about half the thickness of the seal) and see if I can’t make the adjustment to the side walls (which still need to be finalized anyway). So here is a pic of the bottom of the hatch with the 3/16 inch thick shims installed.
The bottom of the hatch now sits perfectly flush with the bottom of the floor, whereas before it was a hair lower. I had also tried 1/4 inch shims (for the ideal 1/3 gasket squish), but had less confidence in that level of squish (the hollow gasket is very soft and squeezes very easily).
At the top you might just be able to see the pencil line that I transferred up using the compass to space off the same amount from the underside of the hatch lip.
And the curb side.
I needed some time to let the ramifications of this sink in, so I found something to do toward forward progress that was necessary, but mundane. I filled the shovel and axe mount bolt holes with shrink wrap. Here are the upper shovel mount holes, for example.
Thinking about the list of things to do to prep for the big side glass layups, I set the trim router up for the chamfering bit that would be needed to trim the door frames for the flox corners; set to 1/4 inch.
Then I sat and had to contemplate it. This was one of those point of no return moments. Once I cut the chamfer in the door jamb I would have to do something to build it back up. I know that is the plan anyway, but up until now there was not the commitment, and this would be committing to a technique that I have not tried or tested yet.
Steeled, I made the cut. Here’s a shot at the street side header and aft upper radius. You can see the interior cabinets in the background, and the inner door seal flange under the chamfer cut I just made for the flox corner.
Committed (or should be) I started making the temporary dams that would help hold the flox in place while it cures. I started by making four corner dams. These will get covered with packing tape as a release agent and screwed to the face of the door frame, along with some straight strips in between so that I can pack the chamfered edge full of flox.
Sure, I might be able to just hand pack the corner w/o this damming, and then sand it back flush to both the jamb and face, but I have not tested this and had some doubt that I could do it as neatly w/o having it all slough off during the cure.
The other option would have been to glass the side; cut the excess cloth out of the door opening; back gouge the jamb under the glass and pack that full of filler before glassing the jamb, but that seemed like more work given that I have the nice (relatively hard) edges of the cedar frame to work off of. Plus the cedar had already been rounded 1/8 inch.
Here you might just be able to make out the temporary dams screwed against the perimeter of the street side door frame. I tried to set them just a hair proud of flush with the jamb so that I would have a touch extra to sand or router back to flush.
And closer up.
I decided not to tip the cabin up. I figured if the header bead dripped out with the cabin tipped up it would land inside of the cabin; whereas if it dripped out plumb it would land on the threshold and be easier to deal with; and with less masking required.
I had intended to brush some wet epoxy down in the groove before adding the filler, but as so often happens I got frazzled once the hardener hit the resin and jumped right to adding the fillers. This time I added a blend of the 403 and 410 fillers to see if I couldn’t get it to flow a little better under the squeegee. Since I had forgotten to wet the wood, and didn’t really want to mix up another batch of neat, I left this mix a little looser than I might have for a thick batch because I wanted to make sure it soaked into the relatively resin rich cedar well enough. I was concerned that it might be too loose and fall out of the header, but this is all a grand experiment anyway, so aimed for the best of both trying to split the difference.
I used the zip lock pastry bag method to feed the filler into the dammed up chamfer, then spread the excess out with the credit card squeegee. The wetter mix with the 410 added did seem to spread a little easier, but that could have just been because it was wetter. Like the hatch corners, it did still seem to soak in and “shrink” below the level of the dams. Hopefully I allowed enough overlap at the dams to account for this, but I may have to do another touchup coat of filler to top it up.
I guess that wasn’t so hard after all. It just took a little time and tinkering to set it up.
Next time I’ll touch this up and see about getting on to the other side.
About the hatch seal change, I’m struggling with the options going forward. If I stick with the original plan to rabbet the outer edge of the galley walls to make a recess for the seal to land on, it will now begin as a rabbet at the top and taper to a full width gap at the bottom. I would still have the benefit of a step inboard of the sealing surface, but only up on the top of the wall, not on the vertical part of the bustle where it would start to fade away. I would also have to hand form the rabbet since the router rabbeting bit would not have a consistent relative surface to guide off of. The other option would be to increase the gap full depth across the full width of the walls, then consider adding back a cap piece to, essentially, form the rabbet again full length; but the existing wall hard edge would get even thinner and I am still worried about maintaining stability in the unsupported edges of the galley walls. Either way I will probably have to make some pucks to keep the draw latches from over compressing the seals, yet give the hatch something solid to dog down against. Karl has some nice strips of Ipe that might be left over from a railing job; maybe I can use those for the caps to reform the rabbets full length. I’ll have to sleep on this… maybe a couple of nights.
Postby Atomic77 » Sun Jan 03, 2016 11:04 pm
You're right KC... There would be no cutting it loose.
Michael
The Astroliner
Atomic77
Images: 309
