RE: Jeep replacement front axle, I couldn't get the carrier to go in with the preload shims due to how the oil relief notches are cut in the bearing seats; they wanted to let the outer races cock and dig in. So I'm waiting on the case spreader tool to arrive in the mail.
RE: TPCE, I was going to work on sanding that big epoxy filler run that sagged down the street side (way back when... it has been months!) but it ended up being pretty cold this weekend and Karl kind of waved me off due to other activities in the shop. A little more peer pressure from you guys (please, nudge, nudge,
) and I just might try again this evening despite being sub freezing out at the moment.
Bodywork is a long tedious process, and I am only so-so qualified to do it... I run out of patience... so don't expect miracles. That winter camo paint scheme is at the top of my options list at the moment.
It does seem like we should be into a short list by now, so let's take a look;
1. Finish filling weave and fairing (including street side rear, street side front, upper front, and hatch... I forget where I left off on the upper front, but at least I don't have to worry about the areas under the rock guards).
2. Fabricate and fit side door latch strike plates.
3. Touch up epoxy work on TB.
4. Install and fair hatch clearance light and taillight nacelles.
4. Sealer/primer coat and paint.
5. Make trim rings and install side door windows.
6. Lower cabin and hatch down from loft, includes fabricating lifting rig (gulp
7. Final install of hatch, doors, and roof vent, do leak test.
8. Fabricate external switch box, install external switch, and test hatch actuator control module.
9. Land cabin on trailer.
10. Install TB, external lighting and do final wiring.
11. Remove roll around wheels/tires and install final wheels/tires
12. Level trailer and weld draw bar (may require longer shackles to optimize suspension travel).
13. Build and install TB lid, rock guards and fenders.
At this point it should be campable. Then;
14. Finish galley and lower/rear vent fan install, including travel provisions for portable solar panels and wing tables.
15. Finish axe and shovel mounts.
Of course there are many smaller steps that make up each of these milestones, and they may not be listed in exact order (for example, I may get the hatch install further along before leaving the loft), but that is my "short list" at the moment.
