Re: Thrifty Alternatives ... Building Foam TDs
Postby Wolffarmer » Tue Jun 19, 2012 2:01 am
If this is the thread where there was talk about bending PVC?
Working PVC
And there are others that pop up there.
Randy
Wolffarmer
Images: 309
Postby GPW » Tue Jun 19, 2012 5:30 am
Yes, Rosey’s results were “floatingly stellar” :applause:
Block fill is easy to find at most any paint store ...
Wolf, I saw about it here : http://www.youtube.com/watch?v=AKjcrEsY ... ature=plcp
Postby eaglesdare » Tue Jun 19, 2012 6:56 am
tb2 and 3 are paintable. i have used both. roll it on and i was good to go. the paint does fill in the weave, but not to the point of having a smooth surface. but it is paintable. :wine:
Louella
May the foam be with you.
eaglesdare
Postby GPW » Tue Jun 19, 2012 7:29 am
One thing to remember about T3 is it does Not like to be glued over with more T3 once it’s cured ... Paint seems fine though ... just something else to remember ...
Postby eaglesdare » Tue Jun 19, 2012 8:01 am
maybe i have a few wierd bottles of the stuff, but i have not had any problems that i am aware of using tb3. i will thank my lucky stars for that.
Louella
eaglesdare
Postby SteveW » Tue Jun 19, 2012 8:24 pm
Grabbed some block fill today and played around with it some. It's like working with really (overly) wet pottery clay. This stuff is heavy, but wondering how much of that weight evaporates away once it dries.
The build is on.
SteveW
Postby GPW » Wed Jun 20, 2012 5:21 am
Thick stuff eh !!! Once the solvent (water) evaporates , it should lose a good bit of weight .... I used a Lot of it to fill my concrete blocks on my house and studio ... works Great !!! :thumbsup:
Postby droid_ca » Wed Jun 20, 2012 11:48 am
Ok a little off topic but still FOAM I want to build a casting deck for my boat would foam work for keeping the weight down and what about standing on it?? Thanks
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby GPW » Wed Jun 20, 2012 12:03 pm
Just skin it on both sides ... ;)
Postby droid_ca » Wed Jun 20, 2012 12:18 pm
so how thin of wood could I get away with?
As I would like to have some storage to tidy it up a bit and was thinking of putting in a live-well. The underside will probably be coated with Truck Box liner to seal it and give it some extra strength but the top will have an Exterior carpet on it so when I bring the dogs they can be comfy too
“Fide Canem”
droid_ca
Images: 176
Postby GPW » Wed Jun 20, 2012 2:41 pm
Wood ??? Just a good canvas should do unless you weigh 20 stone. Perhaps a small center brace to the deck to further eliminate bending ... :thinking:
Postby KCStudly » Wed Jun 20, 2012 2:57 pm
IIRC 1 stone (archaic British unit of measure still in use today) = 14 lbs., so 20 stone = 280 lbs. Not a bad target for design margin. I tend to range in the 18 stone zone, myself.
Postby linuxmanxxx » Wed Jun 20, 2012 3:16 pm
Use stock frame pine 1 x 2 like I do and it's massive strong. Just skin with a hard surface for hottest strength. Formica it's lightest found shop far thats hard enough.
linuxmanxxx
Images: 10
Postby GPW » Wed Jun 20, 2012 4:16 pm
16.4 stone and dropping ... :o
As Luck would have it my neighbor and fellow band member called today and offered me a FREE Trailer ... said he added on to it to make it square ... :D 8) :o On my way !!!!
BTW , he’s a retired welder and really welds Super !!! :beer:
Postby Wolffarmer » Wed Jun 20, 2012 4:43 pm
20 1/3 stones, without me knickers.
:oops:
Randy
Wolffarmer
Images: 309
