obviously I skipped a few steps in the pictures.
using the wallpaper tool I scored up all the foam panels, going over each one many times to get as much pattern into the foam as possible
![117973](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117973)
then I used drywall screws to tack the sides to the frames, these work fine as long as the thread is coarse and you don't over torque them. I thought I would use tape or tywraps, but screws were fine (just like I use on all my wood projects)
![117974](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117974)
and just like that a new mouse was born!
![117975](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117975)
of course a few issues showed up right away. mouse plans are drawn for 1/4" plywood, not 1" foam. I had to trim 1" of each end of each frame, otherwise the bottom panels would be to narrow (by 2"!) this made my frames the wrong shape , and may have changed the shape of the hull slightly (oh well) a quick touch up with the sure form and everything meets up like it should.
![117976](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117976)
since the sides and frames are cut (sort of) square, but the bottom meets them all at a curve, I profiled the edges as best I could guess. (a really nice part about using a glue that is designed to fill gaps and cracks)
![117977](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117977)
since it seems GG and GS (gorrila glue and great stuff) are about the same stuff, just different means of getting it out of the can, I used an idea from the big thrifty thread. work GS until it is in a marshmallow fluff/mustard consistency.
![117978](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117978)
it doesn't take long to get it de-fluffed and ready to glue
![117979](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117979)
using the screws as alignment dowels I glued all the joints, making sure glue oozed out everywhere so I knew the joint was full of glue
![117980](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117980)
then scraping the excess off to use on the next joint
![117981](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117981)
I added some duct tape to each outer corner to keep everything tight, then for the fun of it, I test fit the bottom panel.
![117982](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117982)
just enough width to make the panel (good thing I cut outside the lines on the bottom!)
I made sure to mark the centerline of each frame, this will ensure the boat is (mostly) straight, as the bottom seam will line up with these marks. (my first V bottom, original design mouse)
![117983](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=117983)
