It is a boat trailer and the boat sitting on it is not good. The information plate is really worn, as far as I can make out it is a 1972, and has a capacity of 2250lbs. Not sure of the weight of it thinking it may be to heavy for what I want. would love to be under 500lbs prefer about 300lbs.
The trailer is all bolted together so axle can be moved forward, the avle is below the springs and the main rails are 16" off the ground so if I bring the axle above the springs it would be 13" to the top of the main rails. The 2 main rails are only 36" apart but could be moved 6" out each to be 48" apart. The wheels from outside to outside are 5'-9", so a 7' body would only be 7.5" wider then the wheels on each side.
Here are some pics.
