After taking a break for a couple weeks, I finally got back to working on the trailer. The cross pieces were bolted to the frame, and floor is completely finished and bolted onto the cross pieces. The diy Heims swivel hitch is assembled and mounted into the 2” box steel tongue, and the trailer wiring is all finished.
The side walls go from 18” tall in the front to 5’4” tall at the rear. I made the slant up towards the rear a little more than I had originally planned and I think lowering the front wall from an original plan of 24” to 18” will (?) make it a little more aerodynamic while keeping the side profile lower overall.
I cut out the first arched piece of xps foam for the front of the trailer and pieced together the first side and did a test fit.
The front piece is 18” tall at the sides and arched towards the tongue, but it also had to be arched up in the middle to meet the arched roof panels. Marking that arch and making the cut turned out to be simpler and easier than I feared. I’m using my saber saw with a long sharp and smoothly serrated Bosch blade made for cutting rigid foam and it cuts cleanly and smoothly through the xps as well as the cotton fabric I have on the inside of the arch as the first layer of pmf.
The side wall wasn’t cut down to length yet when I test fitted it and took these photos.
- 2737DB11-D062-41CD-A168-0EB272781FDB.jpeg (411.61 KiB) Viewed 223 times
- 3FDF3C91-2F47-4246-989A-13244D1CDBCA.jpeg (452.05 KiB) Viewed 223 times
