Cabinetry is a great way to stiffen corners when space is at a premium.
Agreed though, sometimes simplicity itself can be eloquent: I was building a line of 43' sailboats when I first started boatbuilding. They had a keel stub that the external lead shoe was bolted to, so there was a foil-shaped 'well' under the floor in the main cabin. In most of them, we would put cleats along the sides so that you could rest milk crates on them. Milk crates are standardized worldwide, cheap, readily available, self draining and don't rot. You could pull them out easily to check the bilge and keel bolts...and it was a SIMPLE solution.
It's available in Canada, so I want to try gluing wood veneer (prob cherry) to styrofoam with the 3M 30NF contact cement that Steve and KC are using.
It will still give me the warmth of wood without the weight of a plywood or MDF(ugh!) cabinet carcass. It will be well sealed, so I'm not too worried about rot.
+1 on cargo nets - I'm putting in hardpoints to attach a couple of gear hammocks above the foot of the bed. In the boat I just finished, I added gear bags to some of the bulkheads. They're like those pocketed shoe holders that go on the back of a door, except that the pockets are various sizes. I've never heard anyone complain about having too much storage space in a boat: I'll be these little trailers are the same !
