Re: Thrifty Alternatives ... Building Foam TDs
Postby droid_ca » Sun Oct 21, 2012 8:23 pm
Wobbly Wheels wrote:Hehe...like filling your tires with helium ?...
Tires what tires we don't need no stinking tires :lol: :lol: :lol:
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby GPW » Mon Oct 22, 2012 6:20 am
Droid , I’m probably the Last one you should be asking about sleds ... I live in the South , no snow ... Only things we have resembling a sled is things we tow behind boats ... :o
But if a sled is like everything else , there must be some major considerations... Things like balance , that’s gotta’ be important , and then there’s the constant flexing .. That has to be stressful on a cabin , unless you have some type of independent suspension. More complexity, expense. maintenance ... :?
Maybe this was all worked out by our ancestors ... simple flexible frame , light weight, locally available materials lashed together with rawhide , and the “cabin” was a couple furs wrapped around the passenger ... seems to be some ancient Logic there ..
In order to incorporate foam into this , maybe the idea of a thick Soft foam “cabin” with an inner and outer canvas skin , like a big Bag , jump in , zip it up ... Insulated , flexes with the frame , rolls up like a big sleeping bag for storage ... little plastic windows sewn in so you can look out , enjoy the view ... :thinking:
Postby droid_ca » Mon Oct 22, 2012 9:36 am
GPW wrote: In order to incorporate foam into this , maybe the idea of a thick Soft foam “cabin” with an inner and outer canvas skin , like a big Bag , jump in , zip it up ... Insulated , flexes with the frame , rolls up like a big sleeping bag for storage ... little plastic windows sewn in so you can look out , enjoy the view ... :thinking:
Now that's what I'm talking about
“Fide Canem”
droid_ca
Images: 176
Postby GPW » Mon Oct 22, 2012 11:06 am
Should be easy enough to make eh ? gotta’ get the Sled first ... :thinking:
Postby droid_ca » Mon Oct 22, 2012 11:33 am
so a tent that hangs withing theframing of the sled... :thinking: I think that is doable
“Fide Canem”
droid_ca
Images: 176
Postby GPW » Mon Oct 22, 2012 12:22 pm
INSULATED, More like a big People Cozy .... with a window ... :D
Postby GPW » Mon Oct 22, 2012 7:48 pm
Like this , a big Padded tent /Cozy ... with thick foam rubber in between the fabric that retains it’s shape ... :thinking:
Postby droid_ca » Mon Oct 22, 2012 8:50 pm
That is AWESOME :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: I love the concept I'll show it to my friend....So your the model plane guy ...Know anything about Ducted Fans :thinking:
Thanks again for the :pictures:
:beer:
“Fide Canem”
droid_ca
Images: 176
Postby Jack B. » Mon Oct 22, 2012 11:40 pm
Nice thing doing a sled, you don't have to deal with highway speeds.
A tent frame on a sled - check.
Clear sheet plastic windows - check.
Super light weight - check.
Pull it with a Vespa. Get to the camp sight and hang it from a tree.
Jack
Jack B.
Postby GPW » Tue Oct 23, 2012 5:36 am
Ducted fans ... The only thing I know is when a Duck walks into a fan , you get pate’... :lol: :lol: :lol: :lol:
Seriously , ducted fans don’t work so well in the “scale “ air ... LESS efficient than a propeller ... " Scale effect" can be demonstrated by observing birds.... Small birds have to flap their wings a lot to fly , while big birds hardly ever have to ... All about the density of the air ... The Bigger the wing , the More lift is created proportionally ... and Drag .
Applied to trailers , the bigger the trailer the more Drag is created ...exponentially more power is needed to tow it .... as we all know by now ... :roll:
Postby pete42 » Tue Oct 23, 2012 5:49 am
pate’
duck walking into a fan congers up a strange visual image....................
pete
pete42
Postby GPW » Tue Oct 23, 2012 5:53 am
Sorry Pete, it’s early ... still on my first cup of coffee... :oops:
Postby droid_ca » Tue Oct 23, 2012 6:49 am
Thanks GPW I knew you would have a good answer...Thats all I needed to know ....For now
“Fide Canem”
droid_ca
Images: 176
Postby GPW » Tue Oct 23, 2012 7:05 am
This is probably a job for a good tentmaker .... More sewing than anything ... Industrial sewing ... You could work out the pattern on large sheets of kraft paper , taped together to see how the parts fit ... Find the right fabric for the outer shell and inner shell , guessing they’d be different ... outer tough , waterproof fabric , inner fabric something softer , warmer .. like a sleeping bag ... Same thing really ... just BIGGER ...
About 2-3” of foam rubber between the fabric (s) will insulate and hold the shape of the design .... heavy duty straps , sewn into reinforced areas secure it to the sled... Like a foamie (sorta’) , just softer foam inside ... Flexible Foamie ‘ Hmmmm? :thinking:
Postby GPW » Tue Oct 23, 2012 7:20 am
This may be a better (easier) Idea ... Run the zipper down the top middle (like a sleeping bag ) split the windows ... entry would be right through the top ... Simple !!! :thinking:
SnoCozy V2.jpg (99.18 KiB) Viewed 1157 times
