While a trailer-cum-boat seems like a great idea, I don't see the end result filling either role particularly well in most cases. To make the idea work you need a flat bottomed boat, which is not a comfortable platform for cooking, sleeping, etc. To get a standy out of something that short, you'll have so much windage that it will be a challenge to move the thing around safely, especially with the low freeboard such a design would necessitate. That's one of the reasons why the slab sides on Ray Bolger's boxier designs have so much freeboard.
When the wind shifts, a flat bottomed boat with a large lateral area tend to heel to leeward before it starts to swing. Because there's so little boat in the water, there's little to damp that heel - it's uncomfortable for cooking or sleeping and can be downright dangerous. If you are moving under power and turn to windward, the leeward bow will 'dig in' and make the problem worse. Typical houseboats have little deadrise at the transom so are quite flat aft (at least by west coast standards) but always have a vee at the bow. Remember that this video was shot in ideal conditions, which isn't ever what you build a boat to.
Then there's the issue of immersing your running gear. Yes, it's done on boat trailers all the time...but they don't see nearly the exposure this one would.
Oh, and there's absolutely nothing wrong with a bit of whimsy Jack !
I absolutely applaud the Sealander guy's ingenuity, but I think a better direction would be to start with a boat on a boat trailer and set it up so that you can camp out of it while on the trailer as well. IMHO a detachable pontoon setup could work, as could a boat that you could slide off a decked trailer. There are some good sized trimarans that are made trailerable by raising the amas out of the water and above the boat - I'm sure one could adapt that technology, especially if it's being done on a smaller, lighter scale.
Starting with a boat trailer would allow you to have a dropped section down the center that would give you the benefits of a footwell in a TD and would give you standy height without so much windage by putting more of the boat in the water...which would also make it better at being a boat. A creative yet seaworthy design wouldn't look like you're taking your boat to a campsite. That said, I have camped a couple nights in a 14' Hourston on a trailer...sleeper seats can be pretty comfy.
But that's just another internet opinion
