Re: Big Bare Essential - Foam Build
Posted: Wed Oct 31, 2018 9:55 am
GPW wrote:"When in the sofa configuration.....that would leave a nice open area” That’s also what we planned with all those cushions ... A little open space is much appreciated ...
This is what is hard to buy....
the 'what' that is individually appreciated....for whatever reason...
For me....some open space is necessary 'not' desired....
But, then.....all open space....with 'nothing' built in.....with everything having to be 'worked' into place....everytime I need to use it....is not going to work for me....
My disability drives my design....or a better way to put it....in a positive light....which is how I roll....my 'abilities' drive my design.....
This is a distinction that is lost on many.....those who view everything as a 'fight' with a winner....someone better than the other....usually measured by size of muscles or miles run, lbs carried....trophies displayed.....
With a 'tool set' of declining, diminishing....value and use....in every avenue of life.....my 'abilities' are in the view of many always in the 'spotlight'.....for me there is no escaping it.....as every moment of every day.....I discover that I can do less and less....with less and less....I choose not to dwell on that....but I can't escape it.....it drives every moment of my life....
Now, it was just ten years ago.....I was like the 'many'......it was 'up, up, and away'.....forever.....and then reality bites hard....and doesn't let go....it doesn't bite everyone the same....such is life.
Since this is 'my' build thread....this is how this one rolls....
this is important.....as anything I might try has to be viewed in this light.....
it has to be measured in so many ways....will I choose to do something not for the 'value' of what it will do for me? but, for the fact that I may only be able to accomplish.....the building it and affording it a different way....and then I will need to happy and grateful for that....
So....
Design requirements revisited....remember I have to do this moment to moment....but staying with the consistent requirements:
Space: is required.....some open space....at all times....
I will need to be able to stand up....straight at least to my neck..(imagining a 90 degrees bend here... )...so my head can touch the ceiling or be slightly slouched....5' 10 1/2" (70.5")....I will need to be able to stand tall enough to change clothes comfortably...I need enough space around me to have a full body tremor....(bet many don't design anything for that?....don't need full height for that....I won't be standing for long)....grab handles everywhere....
I will need to be able to sit 'up'.....with legs outstretched and be able to sit with legs on floor and legs in up reclining position.....
I will need to be able to lay down.....and stretch....violently.....with enough padding or a little space between me and those foam walls that the walls can survive the night....
Any changeover between any of these configurations have to be able to be made very easily....with little effort( no effort would be best...but we have to be practical)
I need enough open floor space to store a mobility scooter on the floor while traveling....(while I am not confined to one....use a cane most of the time....also recently acquired a rollator......oh....the great things in store for some of you..... )......and preferably have enough space to access the potty space without restriction when making a stop while traveling and carrying the mobility scooter....
I will need a light weight (rail) ramp....to get scooter in and out of camper rear door.....so rear door has to be wide enough to accept scooter and floor space has to meet the above....or......I might consider a rear carrier outside the camper for the scooter.....
But, then all design requirements are driven by my current vehicle....and returning from the store yesterday.....a check engine light.....so first thing on the schedule today is to go and pull the codes.....
