Congratulations, you passed the initiation test.
rowerwet wrote:bring a set of four screw in ground anchors http://www.pandjproductsonline.co.uk/sp ... 400mm.html with you for when the warning comes out. not everyplace has a good wind break around, screw them in with the jack handle, strap the trailer down with them and
GPW wrote:Now, just thinking it bowed because it was nailed to a solid surface.... it May (or may not) expand with the foam on a foamie
.... Just thinking about it for window and door frames ..something we can screw on a hinge or trim ring to.
For decking , I dunno’ ... never used it before ... The stuff called decking , I’m sure it works somehow ... Schmaybe’ ???
