My neighbor has a deck made out of that stuff. It is like walking on mini trampolines.. it bounces between 16 inch floor joists. Is nearly twice the weight of comparable wood.. and worse yet? It expands and contracts with temp alot. its broke off the deck screws twice
With that silver bubble wrap stuff? Be careful. I use it at work and it will keep blood products at 98.6 for a insane amount of time in a 70 degree room with no loss of temp. ( box consists of a cardboard box, a layer of plastic bubble wrap, layer of the silver stuff ) So we got the wise idea to line the lunch cooler with it. Stops heat loss, should stop heat gain right? nope nope nope
turns out the stuff is a radiant barrier.. NOT an insulation, in that sense its only R- 1 ( the same as 1 inch of wood).It ref to be effective it has to have a air gap between the thing you are trying to " insulate" and itself. so stacking it to fill a gap in the floor isnt going to help much. heat and cold transfer across it wonderfully Its works much better according to the manufacturer in Hot climates, then in cold where its a waste of money as insulation.
It does so very nicely quilted in between fabric to make a " thermal" curtain.
* in here, some of my dreams become realities, and some of my realities become dreams* - Willy Wonka
