Now I'd just like to mention those "Hard Points " , which is a place to attach a screw to mount your gear ! I plan on hanging some lights , or hooks at least , a cargo net on one wall (very Handy) , and possibly some screw eyes to attach bungee cords over the gear for travel/towing security.
Before assembly might be the best time to plan and install these ... just small scrap wooden blocks inset into the foam , and secured with Gorilla glue. It's easy to slice around the block for the right size , and then just cut away the inside foam to the depth of the block ... and the Gorilla glue will most certainly fill in any gaps . Once the inside covering /skin is applied , these should be barely visible , so remember where you put them ...
Just a small insignificant item that will be much appreciated when you go to fit out your trailer with all the amenities that require an attachment point !!!
And while we're talking about the inside skin ... It would be Very possible to do the inside sides with a thin paneling of some sort , instead of the cloth ...or at least a "wainscoting" up the wall a ways for a more traditional TD look . Since the wooden skins would be directly glued to the foam , and being on the inside of this "encapsulation", I doubt if water would ever get to it ... Would look cool , like a wooden TD .. inside anyway ... Maybe best/easiest to attach these too before assembly ...
