Itty Bitty Foamie Teardrop Test Build Thread
Posted: Sat Sep 16, 2017 12:11 pm
Managed to get a bit more done last night. After an embarrassingly long time trying to get the old wood blade off the miter saw, I was finally able to get it off with the help of a long wrench and a hammer. Got the aluminum extrusion framing cut for the doors! Might have done a little happy dance after the first cut. This is my first time working with anything metal, so it's pretty exciting. Also managed to actually cut everything to the right length, I'm pretty sure. Test assembled one of the doors without fasteners (both inner and outer frame) and it seemed to fit right anyway. Yay!
Also got the frame for the skylight all glued together and fully assembled, and got some paint on there. It fits snugly and beautifully in the opening for it, so that's exciting. Just need to pick which adhesive to use to get it properly glued in there today.
I've also started the process of finishing the countertop. Realized possibly too late that it might have been a mistake doing those big test swatches, since there isn't actually that much left in the cans. Doing the light grey as a base, and then I'll build up as much of the black on top of it as possible. It's time consuming because you have to do one thin coat at a time, let it dry, and then come back for more. So that'll be my afternoon, more or less, in between searching for angles and hardware as I figure out what works best with the aluminum framing that isn't their super expensive bulky hardware.
