Think I have now reached a system I like and very possibly a primer.. Early results of tests look good. I'll get into that later as it cures a bit more.
I moved ahead and primed the roof with enough still in the pan to do one side (except where my set is).
The test is part of the system I'm really starting to like. What I'm looking for is a tight material and when I pul it back it has good resistance. I really don't wish to see all the primer pulled off (unless there's a dent from foam being removed), but a good combination.
The on on the left is what I'm hoping for. The one on the right, not so much.. If that had left a dent, then WHOA, yet it did not, just pealed the primer off.
So far I'm headed towards a great primer coat and let it dry and 50/50 TB2 on the material. I am going to test a lower ratio of water before I proceed, which my mind says 80/20. I like wetting the material and stretching as applying so that would cut the TB2 even further. Doing that seems to draw the TB2 through the material and really stiffens it.
That brings me to the canvas.. I bought the canvas at Harbor Freight and went through the pile but all the had was the 'seam in the middle' canvas.. This gets me real close for doing the roof without that seam.. I wasn't going to pre-shrink the canvas, but now I feel I need to and see if I have enough..
So far it's still damp (had it soaked) and I've lost 4" in width and 6" in length. I can't afford much more (2" more only)...
I have always wanted to wrap the nose and the roof as one piece and will be able to do this. I will have enough to get down the back (hatch area) but not all the way. As I prep canvas, I'll decide where and how that back seam happens.
I hope none of you see this until the weekend is over and your out enjoying and camping somewhere. For me, I'm retired and I'll go once you all are done.. LOL
Safe weekend and travels all!
