Epoxy/Styrofoam Test Panels
It started in this thread:
http://tnttt.com/viewtopic.php?t=44145
and now has a home of its own.
Pasted by way of intro:
"It's not pertinent to canvas really and may not even be relevant to 'thrifty' (at least not generally, though it is for me), but for my build I'll be glassing over the foam. I've been building boats a long time so I have the tooling and the experience, but if one didn't then I think the canvas is a great idea...and ingenious.
As far as using glass cloth with glue, my biggest concern would be ensuring that the cloth is fully saturated. If it's not, any dry fibers will wick moisture and hold it next to the foam. Temperature changes will cause bubbles to stand out and of course you'll get mold/mildew there too. To do that, I'd put the precut glass into a large freezer bag, dump the glue in, squeeze the air out, and go at it with a rolling pin to ensure it's fully wetted. I do that with epoxy layups and it economizes the epoxy (less drips onto the floor). A piece of 3" ABS sewer pipe makes a great roller.
To be completely fair, I haven't tested glue on glass cloth - those are generalizations about resin-starved layups, but dry cloth is dry cloth. The same capillary action that wets the cloth with resin also works on water (and should work on glue too). Personally, I wouldn't use glass mat at all but that's jmho.
I have made up some test pieces to see how structural joints with epoxy, 6oz cloth and 1" foam will perform. I've used EPS (styro)foam & epoxy together before but only for plugs and molds - never for structural panels.
Here is a link to a photobucket album with pics of the test pieces I made - one is an outside corner, one is a panel seam and one is a tab applied to unsanded foam to see the difference in bond strength between sanding and not sanding the foam before layup. When I've got my answers, I'll post up a thread to share what I found out. The next step is to build a scale shell once I figure out how to scale the cloth weight down.
6oz cloth would be overkill for a 1/10 scale model of the body.
EDIT - upping the pics and vid now...I'll make most of this post into its own thread later. I was most surprised that it didn't seem to make a difference whether the foam was sanded or not - that seems counter-intuitive to me. Of course, it applies to epoxy and not T2/T3..."
