Re: RE: Foam Kerfs
Posted: Tue Aug 30, 2011 12:26 am
mezmo wrote:
Maybe I'm reading it wrong as mentioned, but shouldn't the kerfs be
positioned to the outside? That gives a smooth interior wall and no
worry about interior oriented kerf edges lining up and such. Then
you'd just fill in the exterior kerfs with some judicious amounts of spray
foam from a can, and then cut/sand off any excess of that flush with
the rest of the rigid foam
Cheers,
Norm/mezmo
HMMMM I always thought of it as kerfs to the inside of the curve but doing it with the kerfs to the outside of the curve certainly allows for tighter bends, which should help me create the nose of my trailer. If there isn't a large loss of structural strength this would certainly be easier than carving the nose out of a large block of foam.
You may be a genius!!!
