No foam Foamie experiment!
Postby squatch » Fri Aug 12, 2011 2:37 pm
My Foamie is still on waiting on me to finish other projects before I can get started on it. So here is my 1st experiment. I started this right after 1st reading The original Foamie thread. Kind of a proof of concept based on someone else's experiment in that thread.
Anyway I have a sweet old grill I use for camping. It was bought many years ago used a few times and stored (forgotten) in the original box until recently when I pulled it down from the rafters and started using it again. The problem is carrying a dirty grill inside the truck. Trash bags not so good. I wanted light and strong and sorta weather resistant. Something that packed easy.
I took the original box and opened it up and taped the top flaps to extend the sides. Made a matching top. and covered it with TBII and an old bed sheet inside and out.
The materials.
The box partially covered.
I worked in stages covering 1 direction inside and out then letting it dry and coating the other direction In + out.
Glue coating for second ply.
The lid
Extra stiffener for bottom. Coated both sides.
Test fit.
After gluing I covered the whole thing with a coat of diluted glue. The process really saturated the cardboard so I left this thing out in the sun to cook in various positions off and on for a couple of weeks to really cure. Then I used some water based exterior paint I had in the cabinet and gave it 2 coats inside and out. I also cured this in the sun for a couple of weeks. Then I added an old boat cover strap as a lid hold down and handle.
It's now been on a couple of 4x4 camping trips and seems like it will hold up fine over the long haul. I can fit charcoal and started for a couple of days inside with the grill. It is really just a very strong weather resistant cardboard box. Very similar to a fiber drum case now. Only thing I bought was some TBII. Mission accomplished! Not too shabby for a 20+ year old beat up card board box. My wife figures she could stand on it no problem at all.
I intend to use the same process to make some other cases and also some lift out trays with dividers for my action packer style boxes that carry my kitchen stuff.
squatch
Postby Cliffmeister2000 » Fri Aug 12, 2011 2:57 pm
Very nice! Do you carry it by the strap, or pick it up from the bottom?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby squatch » Fri Aug 12, 2011 2:59 pm
Cliffmeister2000 wrote:Very nice! Do you carry it by the strap, or pick it up from the bottom?
Thanks, Either. Neither the box or the grill weigh much so the strap works fine as a handle.
squatch
Postby eaglesdare » Fri Aug 12, 2011 3:10 pm
exactly what i was just talking about in the big long foamie thread.
:applause:
you could make these to use as wash buckets for dishes also. it really works. and is lightwieght. :thumbsup:
Louella
May the foam be with you.
eaglesdare
Postby GPW » Fri Aug 12, 2011 4:17 pm
Squatch ... very COOL !!! Great Re-cycling /Salvage!!!! ... I guess next will be a cardboard bathtub made from an appliance box ... :thinking:
At this rate , won't be long before we'll be bolting them onto trailers ... 8)
Got me wondering now if I could enclose my TD shed with cardboard walls done this way ... ??? :thinking: :thumbsup:
Postby Papi » Sat Aug 13, 2011 5:39 am
GPW wrote:I guess next will be a cardboard bathtub made from an appliance box ...
Hmmmmm... :thinking:
I dream of a day when a chicken can cross the road without having his motives questioned.
Papi
Images: 50
Postby GPW » Sat Aug 13, 2011 7:23 am
You know , once you get started fabricating things with cardboard ,you discover many possibilities ... Only thing to remember about cardboard (corrugated) is that it has a Grain , much like wood ... the corrugations give it that effect ...
If you want to see a site that shows how cardboard can be used for planes (where I learned) , or most anything else (trailers, bathtubs) , with a little imagination ... http://feltondesignanddata.com/
If you can build a plane with it , seems you could build most anything else ... especially things TD related ...
Postby squatch » Sat Aug 13, 2011 1:54 pm
Thanks for the kind words. I really did have a lot of fun making this silly little box. Kinda like art class in grade school. Just get your hands gooey and go for it. 1st project in a long while with no deadline, implications if it's not fixed, immediate need or anything else to cause pressure or a real need to do it. Not really a big deal if it didn't work out. Kinda weird to work like that these days. Nice feeling.
squatch
Postby GPW » Sun Aug 14, 2011 5:08 am
SQ, nice when it all comes together ... I didn't think it was silly at all ... :thumbsup:
Re: No foam Foamie experiment!
Postby djdawg » Fri Nov 16, 2012 10:28 pm
Great experiment...seems like just finding a correctly sized rubbermaid type of container would be a lot less work but cool outcome!
Kevin
Bellingham, WA
djdawg
Postby loaderman » Sat Nov 17, 2012 5:19 pm
yep all cardboard and bedsheets painted on camping trailer, now that would be super-D-duper thrify.
loaderman
